Gasoline Line Leak - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > T-100
T-100 Discussion forum for the short-lived but extremely popular Toyota T-100 model.
Old 12-22-2006, 02:51 PM   #1 (permalink)
View jello1's Photo Gallery
USA Gasoline Line Leak
95T100XcabSR5...190K...gas leak at rubber backet above top edge of tank holding both fuel and return lines...what is easier
1.Drop tank to replace lines...or...remove bed and service
2.Can someone confirm steps for both procedures
3.Can I simply replace bad section of fuel line or should entire piece be replaced
4. Anything better to use instead of the steel line that obviously corrodes
Thanks for help in advance.
jello1 is offline   Reply With Quote
Old 01-06-2007, 05:23 PM   #2 (permalink)
View newbie212's Photo Gallery
It's your fuel sending unit that is leaking.. It's not hard at all to drop the tank... I just had to do this on my 1994.. I replaced all the fuel lines while I was there and got a new fuel sending unit from toyota.. The new unit is $79... I installed all new lines for less than $30... Best move I ever made.. I'd replace the fuel filter while under there too.. More than likely its all rusted.. Hope this helps
newbie212 is offline   Reply With Quote
Fuel Filter Leak...Help ASAP! CarbonRevo 89-95 Toyota Pickup/Hilux 4 10-10-2006 12:28 AM
Stripped Brake Line.... tmak504 3rd & 4th Generation (1992–1996 & 1997–2001) 1 08-11-2006 01:28 AM
Repairing Fuel Line drugal Camry & Solara Lounge 1 09-24-2004 03:38 AM
oil leak charm Camry & Solara Lounge 1 04-29-2003 07:30 PM
