Speedo bounce - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > T-100
T-100 Discussion forum for the short-lived but extremely popular Toyota T-100 model.
Old 04-03-2007, 12:50 PM   #1 (permalink)
mdemeglio's Avatar
View mdemeglio's Photo Gallery
Speedo bounce
My speedometer needle bounces a little bit at most speeds - anyone had this problem before? My hunch would be the speedo cable needs some lube - any thoughts?
mdemeglio is offline   Reply With Quote
Old 04-05-2007, 07:27 PM   #2 (permalink)
View TrustyRusty's Photo Gallery
ACK! My '86 does that, I think they all do it a little bit but if its fluctuating between over 5 mph you got problems bud. Id just WD-40 the cable, I had to do that to my choke the other day cause it was sticking.
TrustyRusty is offline   Reply With Quote
Old 04-08-2007, 01:30 PM   #3 (permalink)
View Royal Tiger's Photo Gallery
I get an annoying buzzing sound when cold from the speedo. How intensive is it to pull the cable, lube , and re-attach? Does it require taking apart the dash? That would be an issue because even with 113k on her, there isn't one sqeak inside the cabin.
Dan
1996 Toyota T100 SR5 XTra-Cab 4x4 (SOLD!)
1996 Subaru Legacy LSi Wagon AWD (For Sale)
2003 aprilia RSV 1000R
2006 Kawasaki KLR650
Royal Tiger is offline   Reply With Quote
Old 05-06-2007, 01:39 AM   #4 (permalink)
View Robin25113's Photo Gallery
I replaced my Speedo cable trying to fix the same thing. $75 from dealer. Helped, but it is probably the rpm speed sensor on the back of the cluster. Electronic tach not mechanical. $250+ at dealer. 96 T-100 4X4 5 spd. Hope this helps.
Robin25113 is offline   Reply With Quote
Speedo error Activator 2nd Generation (2005+) 46 11-11-2007 06:44 PM
URGENT Help - Speedo - Electronic to Manual moberman MR2 Forum 8 07-28-2007 01:05 AM
speedo problem tjyota 4Runner Lounge 0 05-24-2006 01:15 PM
Correcting speedo error: will 265's fit? Activator 2nd Generation (2005+) 4 11-17-2005 08:46 PM
Broken Speedo, Help? Slip_87 ST Celica Forum 3 02-19-2005 04:34 AM
