Locking Hubs - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > T-100
T-100 Discussion forum for the short-lived but extremely popular Toyota T-100 model.
Old 04-12-2007, 04:31 PM   #1 (permalink)
mdemeglio's Avatar
View mdemeglio's Photo Gallery
Locking Hubs
Has anyone converted their front hubs to locking hubs?
mdemeglio is offline   Reply With Quote
Old 05-07-2007, 06:45 PM   #2 (permalink)
View doomvw's Photo Gallery
USA Locking Hubs
Yes I use Warn on my 96 T100.
doomvw is offline   Reply With Quote
Old 05-08-2007, 09:16 AM   #3 (permalink)
mdemeglio's Avatar
Thanks for the reply - couple questions:
1. Did you have to use the Spindle Nut Conversion kit? I can't tell if it's required or if it just makes replacement easier.
2. Did you see any improvement in gas mileage? That's really the only reason I'm considering hubs right now - if it doesn't make a dent in mileage then I'll leave it alone.
Thanks!
Old 05-08-2007, 01:34 PM   #4 (permalink)
View xsacta's Photo Gallery
Thanks!
It's funny, I was wondering the exact thing the other day, regarding gas mileage. There must be a small benefit. There's gotta be an opinion out there somewhere.
xsacta is offline   Reply With Quote
Old 05-08-2007, 02:53 PM   #5 (permalink)
View toyomoho's Photo Gallery
Drivers of other 4x4 report 0 mpg (jeep), 1-3 mpg (Izusu), might get 1 mpg. Read the post below about the results when changing gear oil type.
http://forums.speedguide.net/showthread.php?t=185519
Old 05-08-2007, 03:55 PM   #6 (permalink)
mdemeglio's Avatar
Great link toyomoho - thanks...
I think I'll work the basics first, straight 80W gear oil in the diffs, 5w-30 in the pan, K&N filter with the deck-plate mod, rock hard tires, good coat of wax and 60mph on the highways (if you're behind me - sorry, just go around ;>
Old 05-10-2007, 06:00 PM   #7 (permalink)
USA Locking Hubs
I didn’t need the Spindle Nut Conversion kit. They bolted right up with no problems. Didn’t see much of an increase with gas mileage. I installed the hubs to save my CV joints and front-end parts. I run 38” Super Swampers and my torsion bars are adjusted up a little.
Old 05-11-2007, 09:49 AM   #8 (permalink)
mdemeglio's Avatar
First of all - thanks for the info - very helpful. Second of all: you're running 38's on your T100??!! Pictures please. Sounds sweet!
I think if I had 38's on my rig I'd probably have given up on gas mileage along time ago and just enjoy the ride. ;>
As soon as I can work closer to home I'd like to go with 3" and 33's but that's as big as I can go.
Old 05-25-2007, 12:29 PM   #9 (permalink)
USA Locking Hubs
[IMG] [/IMG] Toyota T100 38" Swampers
Old 05-29-2007, 03:41 PM   #10 (permalink)
mdemeglio's Avatar
They look right at home under your rig. Nice!
Old 05-31-2007, 11:57 AM   #11 (permalink)
mdemeglio's Avatar
Did the hubs last night - cake. Don't know why everyone says you have to have the spindle nut conversion - they fit just fine with the normal spindle nuts. Only question is if I have to keep the little axle bolt & washer on or not - if I tighten it then the axle spins with the hub - if I loosen it a bit then the hub spins freely which is what I want. Don't know if the axle can work it's way out if that bolt is removed or what.
Old 06-04-2007, 10:10 AM   #12 (permalink)
USA Locking Hubs
Are you talking about the bolt and washer that keeps the axle shaft from sliding out? I put those back on. I don’t remember having any problems with that. The hubs are a nice mod. It might not save much on gas but it should save on maintenance.
Old 08-19-2007, 10:10 PM   #13 (permalink)
View speedlever's Photo Gallery
Just joined this forum and found this thread. I put Warns on my '98 T100 soon after I bought it and left it like that for years. The Warns were fine (no conversions needed... straight bolt on after removing the cone washers and flange) but they started to rust a bit as can be seen in the pic below. the Warns looked great inside when I took them off... no rust or anything.
I recently decided to replace the Warns with rebuilt Toyota Aisins. Here's some before and after pics:
Warns:
Aisins:
--speedy
1998 T100 4x4 SR5 ExCab Auto
Aisins, Rhinoliner and Bilsteins
speedlever is offline   Reply With Quote
Manual locking front hubs? toku58 2nd Generation (2005+) 12 05-20-2007 05:07 PM
locking hubs learn2srv T-100 0 01-15-2006 04:30 PM
1999 Tacoma - Manual Locking Hubs or Shift on the Fly? trailrunners 1st Generation (1995.5–2004) 3 02-26-2005 01:08 PM
