1996 T100 tranny oil change. - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > T-100
T-100 Discussion forum for the short-lived but extremely popular Toyota T-100 model.
Old 04-30-2007, 01:08 PM   #1 (permalink)
tomleveq
View tomleveq's Photo Gallery
How do I change the oil in my manual (5-Speed) tranny? How many Quarts to add?
Tks,
tomleveq is offline   Reply With Quote
Old 08-14-2007, 01:59 PM   #2 (permalink)
Helium-3 is the answer
LeftCoast's Avatar
View LeftCoast's Photo Gallery
If it's like any other 5-speeds, you'll have two drain plugs on the tranny housing, near where thr shifter(s) is(are); one will be at the bottom, and one will be on the side @ 3/4 of the way up. You drain all the fluid out the bottom plug, then replace the plug and remove the upper plug, the one on the side high up. I remove the shifter (from inside the cab) and dribble the oil in from the top rather than making some pump arrangement you fill from underneath. But however you get the oil in, once it drips out that upper plug hole, stop filling and let the excess drip out (have a drip pan under this hole already). Reinstall the upper plug and shifter, and you're done. Make sure to use recommended weight for your given vehicle.
GL
LeftCoast is offline   Reply With Quote
Old 08-14-2007, 02:05 PM   #3 (permalink)
tomleveq
LeftCoast
Thank you very much!
Old 08-14-2007, 02:16 PM   #4 (permalink)
LeftCoast's Avatar
No problem. Welcome to TN!
Old 09-26-2007, 11:53 PM   #5 (permalink)
View Mando236's Photo Gallery
Tranny oil change
Is removing the shifter a pain or is it worth the time?
Mando236 is offline   Reply With Quote
Old 09-27-2007, 05:04 AM   #6 (permalink)
LeftCoast's Avatar
In my '92, it's four screws for the rectangular shifter cover "ring", and you press down on the shifter retainer ring (with a rag) and twist counter-clockwise. Pops right out. Biggest PITA is lining up the screws to reinstall the cover.
Men, Women and Oil Changes... BLUEMEANIE Off Topic 15 09-26-2007 10:42 AM
New to oil change, need advice motopasta Archived Corolla threads 5 09-23-2006 02:48 AM
New to the forum, new truck and oil change at 150 miles *PICS* mountain lion 2nd Generation (2005+) 10 09-02-2006 12:39 PM
Manual transmission oil change thebigron Pre-88 Toyota Pickup/Hilux 4 12-14-2005 06:13 PM
About to change my oil on my new camry,what type oil to change it to?high mileage cam Whitecamryghost Camry & Solara Lounge 9 09-26-2005 12:36 AM
