timing belt - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > T-100
T-100 Discussion forum for the short-lived but extremely popular Toyota T-100 model.
Old 05-17-2007, 05:35 AM   #1 (permalink)
View Toughtoy's Photo Gallery
timing belt
Hey peeps I'm going to change my timing belt on my 93T100 v6 210.000k i think it's time.. My question is .. any tips and things to look for that my manual doesn't tell me or avoid any unecessary steps that my manual does tell me to do?? thanks
Toughtoy is offline   Reply With Quote
Old 06-08-2007, 11:02 AM   #2 (permalink)
View vangstang's Photo Gallery
timing
I had the dealer change my timing last year. They recommended changing the water pump at the same time since it is in the area and easy to get to.
vangstang is offline   Reply With Quote
Old 09-27-2007, 12:02 AM   #3 (permalink)
View Mando236's Photo Gallery
Toughtoy, I am sure by now you have changed it. Anything I should know, I am getting ready to do it in two weeks?
Mando236 is offline   Reply With Quote
Old 09-27-2007, 10:17 PM   #4 (permalink)
View 95t100xcb's Photo Gallery
Sorry, I can't offer any hints or tips for changing the timing belt but I can offer some encouragement....you're gonna save yourself a bundle of cash doing the job yourself! I just had the timing belt, water pump, all drive belts, tensioners, both camshaft seals, and thermostat replaced and it cost me almost $900. And it wasn't even done at the dealership I'm telling you, that was painful but I plan on keeping this truck till I'm too old to drive any longer so I'll get my money's worth...Good luck with the job!
95t100xcb is offline   Reply With Quote
Old 09-27-2007, 10:17 PM   #5 (permalink)
Old 10-12-2007, 04:59 PM   #6 (permalink)
View G-meister's Photo Gallery
I did the timing elt on my Tundra 3.4. I used a Tacoma shop manual. Its all the same. To get the crank bolt out, you'll need a huge breaker bar and something to keep the motor from turning. I used a chain-visegrip and a 5' cheater pipe. If it doesn't come loose, just pull harder. You'll also need a vise to re-compress the tensioner. Get some new coolant. I did mine at 100k, and needed nothing else. the belt was $70 from Murry's- the dealer wanted over $400.
G-meister is offline   Reply With Quote
Old 10-13-2007, 09:31 AM   #7 (permalink)
mdemeglio's Avatar
View mdemeglio's Photo Gallery
I'm getting ready to do mine as well, someone posted this link earlier on a different thread:
http://www.4x4wire.com/toyota/maintenance/timing_belt/
Looks like this tool is the only odd-ball thing you need:
http://buy1.snapon.com/catalog/item....&group_ID=1552
(there's a few companies that sell it besides snapon)
mdemeglio is offline   Reply With Quote
Old 10-15-2007, 01:29 PM   #8 (permalink)
I used no such tool. the tensioner comes off and is compressed with a vise or press. That thing just looks shaky. It takes a LOT of force to compress the tensioner, and I wouldn't want put that on the pulleys. Besides, it was easy to remove and only a little fiddling to re-install. Don't forget to pull out the pin after you get the belt on.
My Timing belt change (very detailed, pics) Gen 4 JerryGiese 3rd & 4th Generation (1992–1996 & 1997–2001) 164 11-10-2011 07:40 AM
My Timing Belt Job (Pics) 56k go away Ken4 Camry & Solara Lounge 113 05-18-2011 10:06 AM
Changing V6 Timing Belt Pics and the $270 Coil Connector marc780 5th & 6th Generation (2002-2006 & 2007-2011) 77 02-04-2011 07:08 PM
Timing belt tension spring's purpose AFTER belt install? awmccready Camry & Solara Lounge 4 09-20-2009 03:59 AM
timing belt replaced, now 5 deg atdc?? asm Camry & Solara Lounge 5 07-20-2005 05:22 AM
