Rust on wheel wells - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > T-100
T-100 Discussion forum for the short-lived but extremely popular Toyota T-100 model.
Old 03-11-2008, 04:22 PM   #1 (permalink)
View shawn1032's Photo Gallery
Rust on wheel wells
Hey guys, I have some rust on the wheel wells of my 97' T-100 SR5. Every truck I have seen here in MN has rust in the same place. I have sanded removed all the rust and repainted 2 times but it still comes back. Any suggestion other than MAJOR surgery?
Thanks
shawn1032 is offline   Reply With Quote
Old 03-11-2008, 05:20 PM   #2 (permalink)
T100 Road Warrior...
BamZipPow's Avatar
Gameroom cash: $762810
View BamZipPow's Photo Gallery
You want to use POR-15...
BamZipPow is online now   Reply With Quote
Old 03-11-2008, 05:47 PM   #3 (permalink)
Can that be sanded, painted and clear coated over? The website says it's for frames ect. not body panels.
Old 03-12-2008, 01:45 AM   #4 (permalink)
BamZipPow's Avatar
You could use some electrolysis and create some black iron oxide on the metal...then prime and paint over that.
There are other commercial rust inhibitors that might be easier fer you in the long run. Did you put down a coat of rust prevention first before you primed and painted?
Old 03-12-2008, 11:44 AM   #5 (permalink)
Yes, the first time I sanded, applied naval jelly, rinse, apply rust converter, primed and painted. The second time I sanded, sandblasted all rusted areas primed and painted. In a last stitch effort before performing surgery i was going to drill through the rusted areas and refill with JB WELD sand and repaint.
Old 03-12-2008, 02:23 PM   #6 (permalink)
BamZipPow's Avatar
Did you check behind the wheel well...not sure if the undercoating is still good or not. POR-15 would work well there...
Old 03-13-2008, 11:36 AM   #7 (permalink)
Yes checked inside the well and that could use some por-15, however I believe the rust is originating from the seam at the lower wheel well.
