aftermarket gas tank? - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > T-100
T-100 Discussion forum for the short-lived but extremely popular Toyota T-100 model.
Old 03-22-2008, 01:37 PM   #1 (permalink)
View benny802's Photo Gallery
my gas tank is rusting away... the local dealer said toyota changed the design and a new tank is $628, and i would need a new sending unit at around $130. my truck is a 1995 with 176k. anyone find any aftermarket gas tanks? other ideas? thanks for any info.
ben
benny802 is offline   Reply With Quote
Old 03-22-2008, 03:48 PM   #2 (permalink)
T100 Road Warrior...
BamZipPow's Avatar
Gameroom cash: $762810
View BamZipPow's Photo Gallery
Welcome to the forums!
How badly is yer tank rusted? Is it rusting on the inside? Use the POR-15 Gas tank sealer kit...
If it's on the outside...you could use their POR-15 Rust preventative coating to arrest and halt the rusting now.
Only other option is to git a tank from the parts yard... Try www.car-part.com and save some big bucks!
BamZipPow is offline   Reply With Quote
Old 03-23-2008, 09:20 AM   #3 (permalink)
I haven't dropped the tank yet to find the exact location of the rust... if I only fill the tank half full, it doesn't leak! thanks for the ideas, I'll figure something out!
ben
Old 03-24-2008, 02:12 AM   #4 (permalink)
BamZipPow's Avatar
Git some piccies if you find the location. It would be interesting to see if it's a common area...
Old 03-25-2008, 12:27 AM   #5 (permalink)
View luc_b's Photo Gallery
My gas tank started leaking one day. I phoned everywhere for an aftermarket tank, when I couldn't find one, I looked into getting a new one, and it was going to cost $1400 installed. Instead, I took it to a Radiator repair shop. He took it down, drained it, fixed it and put it back up full for $340.
Apparently rocks and dirt had gotten between the tank and protector and rusted out a square foot of tank. He fiberglassed it and coated it inside and out with a bed lining type gas tank sealer/protector. Have had no more problems and it was quite a bit cheaper.
1995 Toyoto T100 4x4 Xtra Cab SR5
luc_b is offline   Reply With Quote
Old 03-25-2008, 03:57 AM   #6 (permalink)
BamZipPow's Avatar
Looking on Car-part.com the cheapest ones are going fer about $40 and the high side is about $262.50. It's under Fuel tank...
Old 03-28-2008, 04:00 PM   #7 (permalink)
View shawn1032's Photo Gallery
Just replaced mine bought a brand new tank for $400 shipped online. Aftermarket tanks are nonexistant don't waste your time. The rust is most likely located on the underside of the tank just below the straps. Make sure when you wash the truck get that area very well.
shawn1032 is offline   Reply With Quote
Old 08-26-2009, 01:17 PM   #8 (permalink)
View bklynbrn433's Photo Gallery
gas tank
where did you buy the tank, thanks tom
bklynbrn433 is offline   Reply With Quote
Old 08-28-2009, 07:16 PM   #9 (permalink)
View illnastyimpreza's Photo Gallery
would it be a good Idea to use this stuff as a preventive maintenance ?
illnastyimpreza is offline   Reply With Quote
Old 08-28-2009, 07:56 PM   #10 (permalink)
BamZipPow's Avatar
Well...since you already have the tank off and if you follow the instructions correctly/completely...then sure it would be a good choice to do this as a preventative maintenance procedure. Unless you like changing out gas tanks up in yer area...
