Spark Knock? - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > T-100
T-100 Discussion forum for the short-lived but extremely popular Toyota T-100 model.
Old 03-29-2008, 03:09 PM   #1 (permalink)
View funnyguy44444's Photo Gallery
Spark Knock?
My '95 3.4L 5 speed has a pinging spark knock when i accelerate quickly. I have tried using premium fuel with octane booster even and that seems to help but it is still there. So my first question is what octane gas does everyone else put in theirs? Mine seems to run like crap on regular 85. Also how do i solve my spark knock problem? Do i just adjust the timing perhaps?
Thanks,
Nick
funnyguy44444 is offline   Reply With Quote
Old 03-29-2008, 06:24 PM   #2 (permalink)
T100 Road Warrior...
BamZipPow's Avatar
Gameroom cash: $762810
View BamZipPow's Photo Gallery
You might have some serious carbon buildup. Have you tried seafoaming yer engine yet? Give that a try...make sure you follow the instructions on the bottle. You can git Seafoam from AutoZone, Advance, Walmart, etc... It's about $6 a bottle.
BamZipPow is offline   Reply With Quote
Old 03-29-2008, 07:21 PM   #3 (permalink)
Haven't thought of that. I'll go get a bottle and give it a try. Can't hurt anything. Thanks
Old 03-30-2008, 12:13 AM   #4 (permalink)
BamZipPow's Avatar
Make sure you check all yer plugs before you start though. You could have other problems that's not visibly apparent. Would hate to see you have a loose plug and you end up shooting it out of the engine...
Old 04-01-2008, 12:10 PM   #5 (permalink)
I'll make sure there all looking good and nice and tight
Old 04-01-2008, 04:30 PM   #6 (permalink)
Well I think I found the problem. Someone (probably the previous owner) replaced the spark plugs but made two huge mistakes. 1. They only replaced half of them (the three on the drivers side of the engine) and 2. the ones they put in aren't even close to what the correct ones are. So i ordered 6 new nippon denso ones. Those should make a big difference i hope. I used some sea foam and it worked great. It made it run and idle smoother and there is a noticeable change in the power and pickup it has. I'm truly impressed with the stuff.
Old 04-01-2008, 04:51 PM   #7 (permalink)
BamZipPow's Avatar
Do you still have yer pinging?
Old 04-02-2008, 11:45 PM   #8 (permalink)
yea I do but it got a little better after the sea foam. I'm almost positive that when my new plugs come in the mail on friday it will go away completely.
Old 04-04-2008, 10:30 PM   #9 (permalink)
View luc_b's Photo Gallery
What does seafoam do? and what symptoms does it typically remedy?
1995 Toyoto T100 4x4 Xtra Cab SR5
luc_b is offline   Reply With Quote
Old 04-05-2008, 02:56 AM   #10 (permalink)
BamZipPow's Avatar
When used as directed on the can, it can remove the carbon buildup inside the engine combustion chamber. Make sure yer engine is at operating temp before you try though.
There are folks who use a water sprayer instead to do the same thing but they don't flood out the engine and let the water sit.
