Clutch - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > T-100
T-100 Discussion forum for the short-lived but extremely popular Toyota T-100 model.
Old 04-22-2008, 01:10 AM   #1 (permalink)
MakanaMaiKaLani
View matchu808's Photo Gallery
Clutch
I just changed the clutch master cylinder because it was leaking. My clutch pedal now does not want to return at times. I checked the fluid level it was still full but dirty. What could the problem be?
matchu808 is offline   Reply With Quote
Old 04-22-2008, 07:33 AM   #2 (permalink)
T100 Road Warrior...
BamZipPow's Avatar
Gameroom cash: $762910
View BamZipPow's Photo Gallery
Did you bleed out the line? Did you check/rebuild/replace yer slave unit? How good is yer clutch bracket? Any cracks in that?
BamZipPow is online now   Reply With Quote
Old 04-23-2008, 04:03 AM   #3 (permalink)
MakanaMaiKaLani
I changed the slave cylinder at the same time of the master cylinder. I bled the fluid all the way through, but a another question is that how come the fluid became dirty in such a short time? It seems like the brackets are fine and the bushings are fine too. While the engine is off, I pump the clutch four times and on the fifth time I hold it down, it doesn't return. Usually when I drive the car, the clutch hardly returns when its in first gear. Once out of first gear it shifts and clutches just fine.
Old 04-23-2008, 11:41 AM   #4 (permalink)
BamZipPow's Avatar
Since the clutch system is an independent system...it could be a few things.
If you bought all yer items new:
Someone could've switched the internals of one/both units with used parts.
The clutch flex (rubber) line could be bad.
The bleed valve could be bad or not tightened down all the way.
Old 04-23-2008, 12:54 PM   #5 (permalink)
MakanaMaiKaLani
I'm pretty sure the master cylinder and the slave cylinder are good. I bought them brand new. it could be the rubber hose. I guess I'll try replace that and re-bleed the lines. thanks
