Clutch - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > T-100
T-100 Discussion forum for the short-lived but extremely popular Toyota T-100 model.
Old 04-25-2008, 04:51 AM   #1 (permalink)
MakanaMaiKaLani
View matchu808's Photo Gallery
Clutch
If the clutch pedal is getting stuck when I hold it down too long, could it be the pressure plate.
When I hold down the clutch pedal and put it into first, the clutch pedal is stuck to the floor and the car seems as if it caught the gear because it starts to move forward. Is this something to do with the clutch (pressure plate, bearing, or fork) or is it the master cylinder?
matchu808 is offline   Reply With Quote
Old 04-25-2008, 11:44 AM   #2 (permalink)
View toyomoho's Photo Gallery
If it is starting to move forward the pressure plate is engaging the clutch. Might look at a leaking master or slave cylinder, it holds pressure at first then leaks down causing the clutch to engage. Or air in the system.
Old 04-25-2008, 01:05 PM   #3 (permalink)
MakanaMaiKaLani
Is it possible for the master to go within 4 or 5 months? Probably was a defective one or something.
Old 04-27-2008, 12:21 PM   #4 (permalink)
View 97YODAT100's Photo Gallery
mine is in the shop for the same prob!
Hey, ya its your master. I think it is best to change your master and slave at the same time, flush the entire system. My 97'T100 SR5 just got a complete overhaul. New Clutch, the whole deal. 1 week later the clutch petal hit the floor, what a pain in the ass have to reach down and pull it back up.
97YODAT100 is offline   Reply With Quote
Old 05-02-2008, 04:53 PM   #5 (permalink)
MakanaMaiKaLani
did you notice that the return spring is what toyota calls a torsion spring. it doesn't really return the pedal, i have no idea why it's there.
Old 05-03-2008, 03:53 PM   #6 (permalink)
i dont know either, I think its the hydrolic fluid creates suction in the master, and holds the petal to the floor, when i hit it with my foot, raised the petal about a inch from the fllor, it would pop right up fast, i think thats where the spring comes into play
Old 05-09-2008, 02:52 PM   #7 (permalink)
MakanaMaiKaLani
it was just a defective master...thanks for the help
Old 05-10-2008, 04:48 PM   #8 (permalink)
yes sir, I just had a complete clutch job done on my 97 toyota t100 sr5. new pressure plate, throw bearing, everything. And about a week later my clutch dropped to the floor I was pissed! When you change your master, spend the extra time and money on replacing you slave cylinder too, and flush your fluid, making sure its clean.
Hope i helped!, Chris
