wheel bearings - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > T-100
T-100 Discussion forum for the short-lived but extremely popular Toyota T-100 model.
Old 05-05-2008, 12:43 AM   #1 (permalink)
View manny530's Photo Gallery
wheel bearings
i got a 93 t-100 4x4 and i am attempting to change the front wheel bearings an i had a few question do the wheel bearings have to be pressed into the hub an whats the difference between inner an outer bearings. Also i destroyed the 54mm nuts that hold the hub in is this a part i can buy from a parts store if so what do i ask for?
manny530 is offline   Reply With Quote
Old 05-06-2008, 05:21 PM   #2 (permalink)
T100 Road Warrior...
BamZipPow's Avatar
Gameroom cash: $762810
View BamZipPow's Photo Gallery
No...the bearing don't have to be pressed in. The bearing races can be tapped out and carefully tapped in using the right tool...don't use a screwdriver!
The inner bearing (bigger diameter) is the one that rides closest to the inner part of the spindle while the outer bearing is usually the much smaller set and rides to the outer part of the spindle..
Not sure if you can git them there but you should be able to git them from a parts recycling place...
BamZipPow is offline   Reply With Quote
