Originally Posted by BamZipPow
Are you looking to replace/resurface the rotors? If so, you'll need the 54mm hub nut removal tool. Not sure if AutoZone has one of those fer rent or not. To do the pads, it's a pretty simple without taking the caliper off compared to the 2WD where you have to remove the caliper in order to git to the pads.
Some rotor tips...from 4x4wire...
Yeah, replacing the rotors. I had Centric Rotors this last time and they lasted way longer than stock, but living in the mountains they are all warped and need to be tossed.
OK, so I need to find a hub nut removal tool"? That was the info I was looking for!
Thanks!!
PS - they indicate in the article that an inner seal would also be required - correct?
