clutch, now tail shaft?
I'm not happy...to say the least. I had my clutch replaced in my '96 T-100. This was after it was replaced by someone else a couple of years ago. Merchant's Tire did the work this time and I've had good service from them in the past, but this seems a little strange. They finished the job, I drove it around the block and everything seemed fine. Expensive, but the clutch felt good. The next day I noticed a little fluid drippings under the truck. I thought maybe it was just some extra that had dripped off something. The next day there was another spot - maybe 4". I took it up to Merchant's and they checked it and say that I need a rear tail shaft seal and oil pan gasket. I know what an oil pan gasket is, but not sure what the "tail shaft" thing is. But, it seems strange to me that I had had NO drips until they did the work on the clutch/slave cylinder. Now they want $535. to fix this problem -- after $1000. for the clutch. Any thoughts? Thanks.
