95 T100 front end rumbling horrible noise, help!!
New to the site, never posted on a forum before. I have a 95 T100 v6 4wd. Owned it for about 6 years now, replaced a few parts 2yrs ago: front axle half shafts/cv joints, upper & lower ball joints, pitman arm, idler arm, brake lines just to name a few.
Im experienciing a loud kinda rumbling noise in the front end when in drive (2wd or 4wd). I can feel it on my feet & cant tell where its comming from. I took it to my buddys shop, put it on the lift, had it in 4wd & went about 15mph & it didnt make the sound i described. He mentioned my inner wheel bearings are shot, as well as my carrier bearing from the rear driveshaft.
when i did all that work 2yrs ago on the front end, i did repack the outer wheel bearings,
IF my inner bearings are shot, & maybe without the weight from the truck on the tires, (when i had it on the lift) could that be my problem? Also i made sure my transfer case had proper fluid level. Any help would be greatly appreciated!!!!!! dan
