For the topper, most are clamp on. So you should only need a hand to lift it in place, then climb in and place the clamps, then tighten. If the topper has lighting, you may want to run a dc+ wire in there too, but that's up to you. They also may have a 3rd light, which you would splice to the brake wires.
As for replcaement parts (jack, wheels, etc), personally, I like to go to a couple of the local boneyards where I can scope the parts then pull them myself. Whatever years your truck is, you can also find quite a few matches in 4runners of the same year (ex: dash clusters are same, ext mirrors should be pretty close, engines were same, etc).
If you have an ext cab, check under the rear pass seat hatch for the missing jack parts.
riv
96 T100 SR5 4wd
04 Camry SE
