Transmission oil??? - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > T-100
T-100 Discussion forum for the short-lived but extremely popular Toyota T-100 model.
Old 02-07-2009, 07:33 PM   #1 (permalink)
View Hawaiian35's Photo Gallery
Transmission oil???
I have a 1997 T100. Coming upon 100000 miles. Trying to change the Manual Trans oil. I heard that red line sells (75W90) MT-90 Synthetic Gear Oil (GL4 rating!) Sounds good! Right! Well I had a Chevy before my Toyota. I changed the M. Trans oil in my S-10 and it took a crap right after! Wrong oil! non-compatible??? Found out the hard way!!!
The question is... Can use this MT-90 Synthetic Gear Oil in my 1997 Toyota T100??? Please help???
Frank
Hawaiian35 is offline   Reply With Quote
Old 02-07-2009, 07:57 PM   #2 (permalink)
T100 Road Warrior...
BamZipPow's Avatar
Gameroom cash: $762810
View BamZipPow's Photo Gallery
According to my factory service manual...75W90 gear oil...API-4 or API-5 rating. So that should do just fine.
Just make sure you take off the fill plug off first. Don't want to see you drain it before you find out you can't take it off. Seems like who ever did those plugs...put them on super tight. I had to break out the vice grips and a sledge hammer to git my differential plug free...
BamZipPow is online now   Reply With Quote
Old 02-08-2009, 05:26 PM   #3 (permalink)
BamZipPow,
Thx Just didn't want to burn another Trans w the wrong oil! I'll always drive a Toyota truck in my lifetime! I LOVE THESE TRUCKS!!! Thanks again!
Old 02-16-2009, 09:35 AM   #4 (permalink)
View THIRST100's Photo Gallery
wait he said transmission fluid, so shouldnt he be using ATF. Isnt there a huge difference between trans fluid and axle oil? Just makin sure we arent reading wrong, lol.
THIRST100 is offline   Reply With Quote
Old 02-16-2009, 12:07 PM   #5 (permalink)
BamZipPow's Avatar
Thumbs up
Frank
Some people sometimes call it the wrong stuff but they know where it is. If you click his links you can see he's talking about gear oil. Thanks fer watching out fer Hawaiian35!
Old 07-22-2009, 11:50 AM   #6 (permalink)
View 93T100Cook's Photo Gallery
...so its gear oil that goes into the tranny fill hole, yes?
93T100Cook is offline   Reply With Quote
Old 07-22-2009, 12:04 PM   #7 (permalink)
out on bail
fourwd1's Avatar
Gameroom cash: $547055
View fourwd1's Photo Gallery
On a manual trans, gear oil goes into the fill/check hole on the side of the trans.
On an auto, ATF (Auto Trans Fuid)goes into the dipstick tube (on most autos that is).
SEARCH before asking
84 4Runner rockcrawler - ARBed 5.29's, 36" TSLs, dual t-cases w/ 4.7 crawler gear, Chevys, 30 spline Marlins
83 p/u trail rig - Buick 231 V6, Weiand intake, Holley 4 bbl, TH-350 auto w/700R4 low gearset, dual tanks ...
89 4Runner - stock
http://www.cardomain.com/id/fourwd1
fourwd1 is offline   Reply With Quote
Old 07-22-2009, 12:20 PM   #8 (permalink)
Thanks gang!
Old 01-11-2010, 08:50 PM   #9 (permalink)
View illnastyimpreza's Photo Gallery
just curious... where the hell is our gear oil dip stick ???
illnastyimpreza is offline   Reply With Quote
Old 01-11-2010, 09:01 PM   #10 (permalink)
BamZipPow's Avatar
Talking
Um...on the end of yer hand...it's called yer finger.
Manual transmissions don't need a dipstick...unless yer talking about the person behind the wheel.
1998 T-100 SR5 2WD auto, Roadmaster Active Suspension, 6½" dropped front air dam, 4½" drop full belly pan, 4° rear diffuser, 11" side skirts, oil catch jar, AC mod, roof ducktail, aero cap, full grill block
Originally Posted by n c t t o r a
You have used a censored word. Please remove this word.
Old 01-11-2010, 10:43 PM   #11 (permalink)
It doesn't have a dipstick??? O boy.... This truck really is ancient
Every time I go to work on this thing I begin to miss my Subaru more and more... Its just to bad Subaru doesn't make a real TRUCK !
So I'm guessing its just the standard 2 hole gearbox then? Pull top plug...if fluid comes out, its full?
Old 01-11-2010, 11:23 PM   #12 (permalink)
BamZipPow's Avatar
Well..it should be within 5mm of the top of the hole. It shouldn't be pouring out...maybe just a dribble.
Old 01-12-2010, 08:26 AM   #13 (permalink)
You'll most likely need a 24mm wrench for the tranny plug. Mine was overfilled when I checked it by about a quart, so put a pan under it to avoid a mess.
My wife wouldn't get near me for two days because I smelled like burnt tranny fluid.
