Seat Belt Retractor Replacement - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > T-100
T-100 Discussion forum for the short-lived but extremely popular Toyota T-100 model.
Old 02-10-2009, 01:03 PM   #1 (permalink)
1996 T100 Extra Cab 4x4
View captainehh's Photo Gallery
USA Seat Belt Retractor Replacement
Hello All-
I've got a 96 T100 4x4 Extra Cab that I love. Just did a search and was surprised to not find anything under the umbrella of fixing Toyota's notoriously bad seat belt retracting system.
Simple question I guess... Has anyone attempted to remedy the problem? If so, what was involved?
Cheers!
captainehh is offline   Reply With Quote
Old 02-10-2009, 03:09 PM   #2 (permalink)
T100 Road Warrior...
BamZipPow's Avatar
Gameroom cash: $762910
View BamZipPow's Photo Gallery
Yah gotta just know where to look...
BamZipPow is online now   Reply With Quote
Old 02-10-2009, 03:47 PM   #3 (permalink)
This is perfect! Cheers!
Old 02-11-2009, 09:23 AM   #4 (permalink)
dj99's Avatar
View dj99's Photo Gallery
I did the R&R on my belts. It didn't help one bit. I still have to help them retract every time.
1993 Toyota T100 4WD 5-speed (Just over 50K!)
Formerly owned 1989 Toyota pickup 4WD 5-speed
Formerly owned 1985 Toyota Camry Turbo-Diesel
All of the above purchased new
dj99 is offline   Reply With Quote
Old 02-11-2009, 12:57 PM   #5 (permalink)
That's not good news! Anyone else have this experience?
Old 02-11-2009, 01:02 PM   #6 (permalink)
dj99's Avatar
The only thing I did not do (yet) that I have read about is to carefully sandpaper where the belt goes through the upper restraint to make it slide easier. I don't know for sure if it works, but it may be worth a try.
I brought it up to the Toyota dealer once, and they said that's how they are. Like the poor gas mileage. That's the way it is.
Old 02-11-2009, 01:57 PM   #7 (permalink)
Old-phart newb w/clue
View Danno_MN's Photo Gallery
Exclamation
For a low-friction finish, you'd want some pretty fine sandpaper - I'd think that wrapping the bearing surface with a slick-backed tape (electrician's, teflon, etc) would be easier and more effective.
With enough money and effort, you can replace parts on any car and modify - until you end up with a homemade Lear jet. Nothing mechanical is unchangeable.
Danno, who's willing to put up with minor inconvenience before he has parts custom-milled, though.
Danno_MN is offline   Reply With Quote
Old 02-15-2009, 04:13 AM   #8 (permalink)
BamZipPow's Avatar
Question
Did you throw the belt in the washer? No fabric softner and no dryer!!
Old 02-15-2009, 10:24 AM   #9 (permalink)
dj99's Avatar
No, but they haven't worked right from the factory, and the truck is very clean with only 45K miles.
Old 03-20-2009, 10:32 PM   #10 (permalink)
View kylebasa's Photo Gallery
Seat Belt Issue
I have a 96 T100 4x4 and when I bought it as a 2 year lease return, Toyota Certified, it had the retracting problem. Even with the Extended Platinum warranty, I couldn't get the Dealer to fix the problem. They said it had to be broken to get it fixxed. I called it a safety issue, and they still wouldn't fix it.
kylebasa is offline   Reply With Quote
Old 03-20-2009, 11:49 PM   #11 (permalink)
robiewp's Avatar
View robiewp's Photo Gallery
Funny, my car failed inspection in Maine twice because of the seat belt retractor. The inspection code considers it a safety issue and an indication that the active restraint system is failing (not so). It even still works pretty well, just not like from the factory. It does the job when extended to the point required to buckle; it just doesn't keep the belt out of the door without you helping it out.
Third time was the charm though, just had to find a "headlight only" shady inspector.
robiewp is offline   Reply With Quote
