Remove Ignition - Replace with simply 'Switch' - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > T-100
T-100 Discussion forum for the short-lived but extremely popular Toyota T-100 model.
Old 02-15-2009, 12:29 PM   #1 (permalink)
View caferitz's Photo Gallery
Hi Everyone,
I have a 1993 T100 that may be on its last year of life! HA!
anyway it has been a GREAT Truck and has almost 300,000 miles on it.
The ignition-lock-cylinder has locked up and I am not certain if the 'socket' that it fits in
has any problems or not. The lock-cylinder is going to cost me $130 at Toyota.
I want to simply remove the ignition and rewire it to start with a switch.
Has anyone done this, or have a suggestion where to research the wiring and what
can and can not be 'by-passed' ?
Thanks for any help or ideas that anyone has!
AL
caferitz is offline   Reply With Quote
Old 02-15-2009, 03:03 PM   #2 (permalink)
nooB nooB noo
View Larzzzz's Photo Gallery
The switch itself maybe on the steering column under the dash. Get a can of contact cleaner, not carb cleaner and spray inside the lock to clean it out. flush it out, let it dry and get some graphite lock lube for it. Spending $20. is better than $130.
BTW carb cleaner will attack plastic and should not be used!
'06 DCLB Indigo,Scangauge II, Redline tuning hood struts, map light mod, trailer plug mod, LED bed lights Thule X-sporter racks. Aux. back up lights.
Larzzzz is offline   Reply With Quote
Old 02-18-2009, 07:55 PM   #3 (permalink)
out on bail
fourwd1's Avatar
Gameroom cash: $547055
View fourwd1's Photo Gallery
The key-lock and the actual switch are 2 different parts, connected together, which is bad ? (sounds like the lock part). Changing the switch part is a lot easier than the lock part.
SEARCH before asking
84 4Runner rockcrawler - ARBed 5.29's, 36" TSLs, dual t-cases w/ 4.7 crawler gear, Chevys, 30 spline Marlins
83 p/u trail rig - Buick 231 V6, Weiand intake, Holley 4 bbl, TH-350 auto w/700R4 low gearset, dual tanks ...
89 4Runner - stock
http://www.cardomain.com/id/fourwd1
fourwd1 is offline   Reply With Quote
