Replace glass in driver side mirror - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > T-100
T-100 Discussion forum for the short-lived but extremely popular Toyota T-100 model.
Old 02-21-2009, 05:12 PM   #1 (permalink)
View snwcmpr's Photo Gallery
I can get the glass from the dealer (about $38) instead of buying the whole electric mirror (over $200).
My question is:
How do I change the glass?
I can't find any instructions or pictures anywhere.
The dealer here in NC said they don't do it, because they break the glass too often.
Ken
Proud new owner of a '95 Kingcab T100.
snwcmpr is offline   Reply With Quote
Old 02-21-2009, 07:49 PM   #2 (permalink)
dj99's Avatar
View dj99's Photo Gallery
Check this out:
http://cgi.ebay.com/ebaymotors/93-98...Q5fAccessories
Can't beat $20 bucks + easy!
1993 Toyota T100 4WD 5-speed (Just over 50K!)
Formerly owned 1989 Toyota pickup 4WD 5-speed
Formerly owned 1985 Toyota Camry Turbo-Diesel
All of the above purchased new
dj99 is offline   Reply With Quote
Old 02-22-2009, 02:50 AM   #3 (permalink)
robiewp's Avatar
View robiewp's Photo Gallery
Also see this discussion:
Drivers side mirror
If you want to actually replace the glass, there is a single philips screw that is in a hole under the mirror (get down on your knees and look up from the bottom). If I remember correctly this screw is all there is to it. Undo the screw and pivot the mechanism up.
Cheers,
Rob
robiewp is offline   Reply With Quote
Old 02-22-2009, 12:29 PM   #4 (permalink)
Old-phart newb w/clue
View Danno_MN's Photo Gallery
The link in that thread (from 65riv) is where I got the replacement glass for mine - quickly shipped, looks to be right, and like that - I'd been waiting for warmer weather before I actually put in the new glass, though - it comes with double-sided tape that probably sticks better when it's not freezing.
I was planning on just breaking out the mirror that's in there - it's already cracked pretty badly. If robiewp's screw is accessible, I can bring the thing inside, let the adhesive cure overnight, and put the new one in, regardless of Minnesnowta weather. Thanks, Rob!
Danno
Danno_MN is offline   Reply With Quote
Old 02-22-2009, 12:32 PM   #5 (permalink)
dj99's Avatar
The difference between the two stick-on options is that the one on ebay is already cut to fit exactly.
Old 02-22-2009, 05:32 PM   #6 (permalink)
I'm not gonna use taped glass
Half of the mirror is broken away.
I am going to replace the mirror with Toyota part ... cuz I can.
I would use an after market, if I had to.
But, thanks alot for all the responses.
Ken
'95 T100 king cab (Over 245 K)
Mud King XT 31x10.5xR15
Old 03-15-2009, 03:05 PM   #7 (permalink)
Follow-up on mirror replacement
I did get the mirror assembly out with a screw accessed from underneath. That was easy enough.
But, I see now why Toyota dealer here said they don't do that, cuz too many mirrors break installing it.
The double back tape is easy to apply the mirror to the assembly.
The trouble came trying to get the mirror underneath the exterior banding that holds it on. It is a hard rubber like trim, and wouldn't bend enough to get the glass all the way underneath it. The glass wold have broken forcing it.
So .... I took the assembly off of the door, brought it inside, and heated it with my GF's blow dryer. Wham Bham, it went in, recessed under the trim, just like it's supposed to look.
Thanks for the help,
Ken
Old 03-16-2009, 01:48 AM   #8 (permalink)
Sweet idea! I don't have a blow dryer, but a heat gun (or soaking in hot water) should do the same trick. We've got warmish here, so I think I'll be doin' mine tomorrow. Thanks for the followup, Ken!
Danno, actually thawing out.
Old 03-16-2009, 02:13 AM   #9 (permalink)
T100 Road Warrior...
BamZipPow's Avatar
Gameroom cash: $762810
View BamZipPow's Photo Gallery
Um...probably soaking in water wouldn't be a good idea if you git the motors wet...
BamZipPow is online now   Reply With Quote
Old 03-16-2009, 07:32 AM   #10 (permalink)
I only heated up the rubber like trim around the plastic base for the glass.
The screw released this part from the whole mirror assembly.
No motor or any electrical parts involved.
Old 03-16-2009, 10:08 PM   #11 (permalink)
BamZipPow's Avatar
Talking
I was responding to Danno's post about using hot water...
Old 03-17-2009, 12:39 AM   #12 (permalink)
Talking
Well, if the screw releases the part from the electrical parts, the hot water should do fine. Mostly, I don't soak electrical parts unless I can certify them dry afterward (like open switches) - and those, mostly in contact cleaner. Mostly, I don't hit electric motors/relays with a heat gun, either. They're no good once you let the smoke out of 'em.
I'm not really as dumb as I look. Really. Unless we're playin' poker - in which case, you should think I'm even dumber than that.
Danno, who once actually filled an inside straight. Once. Was hopin' for a pair, 'cause I didn't believe his flush.
Old 05-03-2009, 07:39 PM   #13 (permalink)
Followup, 'cause it occurred to me.
1 - Robiewp's screw is right there - a small hole in the exterior case leads to a phillips screw that's really easy to lose in my dirt driveway. Rare-earth magnets are great for finding small metal parts like that.
2 - I could not figure out how to get the easy-tip-out assembly disconnected from the wiring, so I ended up putting it back in and waiting for warmer weather.
3 - The mirror I got was not quite right - a touch too long, not quite tall enough. Since my beast was totaled at one point, I don't know that the outside mirrors weren't from a different model year, so I can't complain to the supplier. Workin' the glass (mirror on both sides, probably fits either side mirror) down with a stone should be a soonish project, but it's held on so far, and I've got other stuff to do. (A coarse sharpening stone, like the kind used to sharpen scythes, will take the sharp out of glass edges, and wear it down middlin' fast. Work along the side, not perpendicular to the glass, and use a dust mask - the dust is really really nasty to the lungs.) With it not too long, the minimal height difference will probably just make it easier to get it in behind the edge protector (which is, after all, attached to the motors.)
Danno, avoidin' an ugly job in the workshop.
Last edited by Danno_MN; 05-03-2009 at 07:41 PM. Reason: edited to clarify a point
Old 05-03-2009, 09:48 PM   #14 (permalink)
View redsky01's Photo Gallery
I just broke mine today...
I looked up on the web and found that this one seems to be good
http://www.rockauto.com/catalog/rafr...1428937k704948
40$
mine is toyota camry black LE ( 4 cyl.)
what I broke is driver side mirror...
I beleive mine is non heated.
any one here ever tried getting a mirror from them or someone similar..?
the toyota dealer is asking for 250+
auto spare parts dealers like Kragen say it is around 150
this site and a few others sell at around 50 -
wonder why so much difference
redsky01 is offline   Reply With Quote
Old 05-04-2009, 12:54 AM   #15 (permalink)
I suspect that Kragen and the dealer are sellin' you the power adjust unit with mirror installed, while the other folks are just sellin' you the mirror that fits.
See my posts earlier in this thread on the trials and tribulations of buyin' just the glass - and maybe someone'll chime in with an easy way to unhook the power wires from the mirror chassis so you can make the swap sitting down, at a workbench, rather than standing next to your truck door.
Danno, glad of his background in stained/etched glass....
