Thermostat Vs. No Thermostat - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > T-100
T-100 Discussion forum for the short-lived but extremely popular Toyota T-100 model.
Old 03-13-2009, 12:34 AM   #1 (permalink)
MakanaMaiKaLani
View matchu808's Photo Gallery
Tell me what you guys think. Should I run a thermostat or not. I know the engine will heat up faster with the thermostat, but then again I know you don't need one either.
matchu808 is offline   Reply With Quote
Old 03-13-2009, 12:49 AM   #2 (permalink)
THIS SPACE FOR RENT
humanoid's Avatar
Gameroom cash: $902364
View humanoid's Photo Gallery
A thermostat was placed there for a reason. If you don't have one your truck won't get up to normal operating temperature and your truck will probably give you problems down the road. The automotive engineers put one there for a reason, just leave it be.
This is my sig.
humanoid is offline   Reply With Quote
Old 03-13-2009, 01:47 AM   #3 (permalink)
T100 Road Warrior...
BamZipPow's Avatar
Gameroom cash: $762810
View BamZipPow's Photo Gallery
If yer engine runs too low on temp too long, yer ECU will throw a code eventually. It's not that hard to replace the thermostat...
BamZipPow is offline   Reply With Quote
Old 03-13-2009, 04:35 AM   #4 (permalink)
Dave's
View Dave's's Photo Gallery
Pretty sure low temp will increase fuel use as well. If a t-stat stuck closed on me at a point I couldn't easily get a new one, I'd pull it and do without until I could. However, I wouldn't recommend running without one as a normal condition.
Dave's is offline   Reply With Quote
Old 03-13-2009, 07:50 AM   #5 (permalink)
Resident asshole
Flashmn's Avatar
Gameroom cash: $350545
View Flashmn's Photo Gallery
....and running without a thermostat, you have no flow restriction, will have actually much less cooling, the bypass channel for coolant wont ever close and the normal flow of coolant will be hampered.
You're begging for alot of problems running without a thermostat.
Old 03-13-2009, 01:15 PM   #6 (permalink)
ShawnM's Avatar
View ShawnM's Photo Gallery
Thats one of those old school tricks that really dosent apply to modern engines. If you dont want any problems with it just leave the t-stat alone and change the coolant at the proper intervals.
--Shawn
03 Camry LE
97 Lincoln MarkVIII LSC
67 Mustang
ShawnM is offline   Reply With Quote
Old 03-13-2009, 04:45 PM   #7 (permalink)
Kookadala's Avatar
View Kookadala's Photo Gallery
A thermostat costs like what - 10 bucks tops? Two bolts and its installed. Put a new one in.
Kookadala is offline   Reply With Quote
Old 03-17-2009, 07:06 PM   #8 (permalink)
MakanaMaiKaLani
thanks guys. I was thinking it didn't really matter because here in hawaii the weather never really gets cold, but i guess you guys are right, its there for a reason so leaving it is the best bet. what do you guys think about the trd one?
