oil pressure ?? - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > T-100
T-100 Discussion forum for the short-lived but extremely popular Toyota T-100 model.
Old 03-13-2009, 01:05 AM   #1 (permalink)
23skidoo's Avatar
View 23skidoo's Photo Gallery
oil pressure ??
Just purchased my first T100 yesterday. I hauled a ton and a half of landscape boulders today and noticed the oil pressure gauge (gauge above the engine temp gauge) was on the low side. Is this
typical ? At a standing idle it's dead low, at high speed it reads a little over a quarter on the gauge.
Oil volume is normal and temp is dead center when fully warm. Should I be concerned ? Are these gauges accurate and if they are what would be the proper reading ?
23skidoo is offline   Reply With Quote
Old 03-13-2009, 01:45 AM   #2 (permalink)
T100 Road Warrior...
BamZipPow's Avatar
Gameroom cash: $762810
View BamZipPow's Photo Gallery
Yes...the T-100 is notorious fer the low pressure. It will be fine.
BamZipPow is offline   Reply With Quote
Old 03-13-2009, 10:46 AM   #3 (permalink)
greent's Avatar
View greent's Photo Gallery
The 3.4 runs about 3-5 psi at idle, and 40 plus at higher RPM. First I would verify with a mechanical gauge. Mine was reading about the same way, and I found the sender to be at fault. They seem to read lower the older they get.
greent is offline   Reply With Quote
Old 03-13-2009, 04:51 PM   #4 (permalink)
Kookadala's Avatar
View Kookadala's Photo Gallery
It usually reads normal when you first start up and the engine is cold. Once things warm up, they all read low but the pressure is still normal
Kookadala is offline   Reply With Quote
Old 03-13-2009, 10:36 PM   #5 (permalink)
23skidoo's Avatar
thanks for the quick responses fellas. This seems like a pretty lively forum compared to some others. When I have a minute I'll check the sender unit.
As I said this is my maiden voyage with the T100 and I'm very impressed. Found the truck on craigs list for $3500 with 150,000 miles and a reconditioned title. New paint, very clean interior, 5-speed, 2WD, X-cab. From what I could determine the only damage was to the left fender and it wasn't replaced just straightened. All body panels still had their original corresponding VIN #. Truck shifts and runs smooth and can pull a load. This is a major upgrade from my bulletproof 86 SR5 4 banger. I guess I should introduce myself in the welcome section sorry to go in the back door here.
Old 03-16-2009, 09:25 PM   #6 (permalink)
MGoBlue's Avatar
View MGoBlue's Photo Gallery
Some fresh oil will give you a little more needle.
MGoBlue is offline   Reply With Quote
Old 03-17-2009, 12:03 AM   #7 (permalink)
epe
View epe's Photo Gallery
The t100 I just bought runs the same oil pressure.. Made me wonder too. Has new oil in it..
epe is offline   Reply With Quote
