Rear Differential Breather Valve - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > T-100
T-100 Discussion forum for the short-lived but extremely popular Toyota T-100 model.
Old 07-04-2009, 08:32 AM   #1 (permalink)
View 93T100Cook's Photo Gallery
Starting off a new thread based on Hartzog's thread....
I started leaking gear oil on the RD. I thought is was finally rusting through. Found Bam's comment on HZ's thread about the breather valve. Found the vavle, unbolted it with a 14mm and cleaned it out, found the hole, and pulled out the most trustworthy tool of all time, the paper clip!
Cleaned it out real good and ran the clip through the breather hole. Drove it around for a few, then parked it and only a couple of drips. I'm hoping that was leftover oil in the seal.
Bam said when that valve gets gunked up/clogged, pressure builds up in the housing and pushes oil through the seals. After a visual inspection, that appears to be what was happening. I'll follow-up in a few days and let everyone know if the link completely stops.
Thanks again and this goes to show this sight is a wealth of information!!
Cook
93T100Cook is offline   Reply With Quote
Old 07-04-2009, 01:28 PM   #2 (permalink)
T100 Road Warrior...
BamZipPow's Avatar
Gameroom cash: $762810
View BamZipPow's Photo Gallery
Now you just have to do the remote breather mod and you'll be all set...
Better check those rear brakes...you might have oil on them. Wouldn't want you to find out the hard way you can't stop...
BamZipPow is offline   Reply With Quote
Old 07-04-2009, 09:08 PM   #3 (permalink)
Oil hit the shocks, but shy of the breaks, barely, but I caught it soon enough.
What's the "remote breather valve?" In school right now and not a lot of time for research
Later Bam, and as always THANKS
Old 07-04-2009, 09:38 PM   #4 (permalink)
BamZipPow's Avatar
Search is a wonderful thing...
Old 07-07-2009, 09:06 AM   #5 (permalink)
View Hartzog's Photo Gallery
On my 1996 T100, i noticed after i cleaned the breather on my rear axle, it stopped leakin so bad, so im wondering if my carrier bearing is bad or not......im sure it is as it still makes noise and vibrates.....but as soon as i can earn $20 i will get the seal, and put in the thirdmember i bought, found a good deal in it, thanks to bam=]
Hartzog is offline   Reply With Quote
Old 07-11-2009, 06:47 PM   #6 (permalink)
BamZipPow's Avatar
It would benefit you greatly if you had a machine shop check over that third member before you install it.
