3.4 V6....found a problem.....help needed... - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > T-100
T-100 Discussion forum for the short-lived but extremely popular Toyota T-100 model.
Old 07-09-2009, 05:51 PM   #1 (permalink)
View Hartzog's Photo Gallery
Yep, i was under the hood the other day, and noticed a possible oil leak.....
Its right around the oil filler cap area, and i checked the oil....and noticed it had a slight hint of gas to it.......NOT GOOD......wat could this be....??
is this a common problem with these trucks?
heres a few pics of the problem...
Hartzog is offline   Reply With Quote
Old 07-09-2009, 07:40 PM   #2 (permalink)
Somewhat Useful!
View Bhubs's Photo Gallery
USA
At first look, it appears that whoever (maybe you) spilled some oil on the valve cover during your last oil change.
If that is not the case, then put a socket on the valve cover bolts and see how tight they are (mine were VERY loose). You might be due to change the valve cover gaskets which I did a few weeks ago and has fixed my problem.
One other common area that might be leaking is the back side of the valve covers closest to the firewall. When the engine is cool, rub your clean rag back there and see if you have oil. If so, then you probably have oil dripping down the back.
Hope this helps.
Bhubs is offline   Reply With Quote
Old 07-09-2009, 10:34 PM   #3 (permalink)
PostMortem User
View narksuwan's Photo Gallery
That's so embarrassing. Could at least clean that engine before taking picture.
'86 Toyota Cressida 2.8 - super cool station wagon
'95 Toyota T100 3.4 - 1 ton mod stake/flat bed
narksuwan is offline   Reply With Quote
Old 07-10-2009, 04:02 AM   #4 (permalink)
Procrastinating on TN
knj27's Avatar
View knj27's Photo Gallery
wouldn't want to clean the oil stain off though, now would we?
You pretty sure your oil smells like gas?
'93 Pickup 4x4 22R-E
knj27 is offline   Reply With Quote
Old 07-10-2009, 07:33 AM   #5 (permalink)
Mmmm Cookies....
Zuke76's Avatar
Gameroom cash: $200682
View Zuke76's Photo Gallery
It looks like you missed when adding some oil... Don't worry it happens to all of us. I call it chassis lubrication.
03 4Runner V8 4x4 SR5
96 T-100 4x4 SR5 (traded)
97 Corolla CE (totaled)
94 P/U 4x4 (traded)
Zuke76 is offline   Reply With Quote
Old 07-11-2009, 03:02 AM   #6 (permalink)
knj27's Avatar
^thought about sayin' that myself
Old 07-11-2009, 04:38 PM   #7 (permalink)
yes, the oil has a smell of gas to it, i thought it did, so i had about 5 other people smell it, all said gas, i am goin to change the oil soon, and then drive it about 100-400 miles and re-check it
will also check all valve cover bolts etc.
Old 07-11-2009, 06:41 PM   #8 (permalink)
T100 Road Warrior...
BamZipPow's Avatar
Gameroom cash: $762610
View BamZipPow's Photo Gallery
Did you check yer PCV valve lately?
How good of a condition are those injectors? Yes...even the cold start one...
What's yer cylinder pressures running? How good is that fuel economy doing? Did you ever replace those spark plugs yet?
BamZipPow is online now   Reply With Quote
Old 07-12-2009, 03:52 AM   #9 (permalink)
knj27's Avatar
well pretty much anything in your car except the gas smelling like gas is always kind of a big deal, so after you change i really hope you don't notice it again
Old 07-12-2009, 04:27 PM   #10 (permalink)
where is the PCV valve??
i have been un-able to check my mileage lately, cause i never have the money to fill it completely up, lol
and idk about the cylinder pressures, but yes, i put new sparkplugs and wires on it, and also cleaned out the intake box, new airfilter.
and btw, the check engine light isnt on, but i took dash out even, to make sure somebody hasnt tooken the bulb out before
Old 07-12-2009, 04:33 PM   #11 (permalink)
Somewhat Useful!
The PCV valve is located on the top of the driver's side valve cover towards the front of the truck. There is a rubber hose connected to it and to remove it just pull. I bought a replacement and a new gasket and it took just a few minutes to replace.
My gasket was dry rotted and I had to cut it out. Learn from my mistake and know that the old hard gasket may fall into the valve cover (which happened to me). If you have to cut out the rubber gasket, have a pair of needle nose plyers handy to hold onto the gasket or you'll spend time fishing it out.
Old 07-12-2009, 06:13 PM   #12 (permalink)
sounds like somethin i better wait to mess with, as i have about $4 to my name at the moment, lol
Old 07-12-2009, 07:21 PM   #13 (permalink)
BamZipPow's Avatar
You could pull it and check it...if it's gunked up...at least you might be able to clean it with some degreaser/cleaner/acetone. Just don't use and gasoline!!
Old 07-13-2009, 02:07 AM   #14 (permalink)
lol bam, did i mention......i checked valve cover bolts, adn they were pretty loose, but didnt look it, so everyone with the 3.4L V6, check your valve cover bolts!!
Old 07-13-2009, 02:32 PM   #15 (permalink)
Somewhat Useful!
I guess the "loose" valve bolts are common....I could have taken my covers off with no tools, just my fingers to loosen the bolts. No wonder I had oil leaking down the back of my engine!
