Jumping starter solenoid? - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > T-100
T-100 Discussion forum for the short-lived but extremely popular Toyota T-100 model.
Old 07-14-2009, 04:49 PM   #1 (permalink)
View joe citizen's Photo Gallery
USA Jumping starter solenoid?
Ive got a 96 4wd T100. The truck was running fine, I parked it and two hours later I was planning on going to the store but it wouldnt start. The engine doesnt turn over at all nor are there any clicks from the engine when I try to start in. The battery is new so that is not the problem. Im guessing there is probably something wrong with the starter or soleniod and Im wondering how I would try to jump start the starter soleniod to see if thats the problem.
joe citizen is offline   Reply With Quote
Old 07-14-2009, 06:26 PM   #2 (permalink)
T100 Road Warrior...
BamZipPow's Avatar
Gameroom cash: $762910
View BamZipPow's Photo Gallery
I would still test the battery and then yer cables. You said there wasn't any clicks at all? I guess you could tap the starter with something...
Is this a manual or auto transmission? If this is an auto, did you make sureit was all the way in park? Have you tried it in neutral?
BamZipPow is online now   Reply With Quote
Old 07-14-2009, 07:19 PM   #3 (permalink)
USA
It's an automatic. I tried it in park and I tried it in neutral. The lights and everything will come on full force and will stay on if you try to start the engine but it just doesnt crank over at all and there is no clicking whatsoever. I was thinking it might be the solenoid and was going to try to jump it to test it out but looking at the starter/solenoid Im not sure what I would be jumping as it doesnt look like the old style Im used to.
Old 07-14-2009, 10:38 PM   #4 (permalink)
Mmmm Cookies....
Zuke76's Avatar
Gameroom cash: $200682
View Zuke76's Photo Gallery
Starter contacts.
03 4Runner V8 4x4 SR5
96 T-100 4x4 SR5 (traded)
97 Corolla CE (totaled)
94 P/U 4x4 (traded)
Zuke76 is offline   Reply With Quote
Old 07-14-2009, 11:00 PM   #5 (permalink)
BamZipPow's Avatar
Give the starter a good tap and see if it will start. If it works, then it's the contacts fer sure...
Old 07-14-2009, 11:43 PM   #6 (permalink)
Well I gave it a few taps and that didnt do anything so I borrowed my neighbors multimeter just to see how many volts the starter was getting and its around 12.65 volts.
Old 07-15-2009, 02:05 AM   #7 (permalink)
BamZipPow's Avatar
It could be yer neutral switch on the trans...looks like you need to check fer continuity on 5 and 6 when it's in park or neutral. It should have continuity when it's in those positions.
I'd still check yer wiring connections on the starter...especially the ground.
Old 07-16-2009, 12:57 PM   #8 (permalink)
out on bail
fourwd1's Avatar
Gameroom cash: $547055
View fourwd1's Photo Gallery
To check the solenoid/starter, turn the ign sw to the RUN position.
Connect a fairly heavy gauge wire (18 or heavier) to the battery + terminal
Then touch the other end to the solenoid terminal.
If all is OK the solenoid should click and the starter should turn.
SEARCH before asking
84 4Runner rockcrawler - ARBed 5.29's, 36" TSLs, dual t-cases w/ 4.7 crawler gear, Chevys, 30 spline Marlins
83 p/u trail rig - Buick 231 V6, Weiand intake, Holley 4 bbl, TH-350 auto w/700R4 low gearset, dual tanks ...
89 4Runner - stock
http://www.cardomain.com/id/fourwd1
fourwd1 is offline   Reply With Quote
Old 07-20-2009, 08:21 AM   #9 (permalink)
OLD SCHOOL
xsvtoyz's Avatar
View xsvtoyz's Photo Gallery
I am going to play captain obvious and ask did you check for power on all the fuses? use a test light and verify power? also put the key in start and ratchet the gear selector from P to 1 and back see if it makes any attempt. Verify the starter trigger wire is in place? check the fusible link form the battery to the fuse box under the hood?
to jump start the solenoid a 12 guage or better wire from the 12 volt started power and over to the trigger very short run and the the starter should throw the gear and spin.
THE BLACK PEARL
recent mods: one eyed jack-in-the-box ball
xsvtoyz is offline   Reply With Quote
