FJ Rims - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > T-100
T-100 Discussion forum for the short-lived but extremely popular Toyota T-100 model.
Old 07-26-2009, 12:05 AM   #1 (permalink)
jv coach's Avatar
View jv coach's Photo Gallery
USA FJ Rims
Has anybody installed rims from a current FJ. I cant seem to install the front caps and want some ideas or pics on how to fix my problem. I have a 95 4x4.
jv coach is offline   Reply With Quote
Old 07-26-2009, 06:46 AM   #2 (permalink)
robiewp's Avatar
View robiewp's Photo Gallery
Coach,
These are the FJ wheels I have:
hubcaps are impossible on the front for a 4x4. If you've seen a t100 with FJ wheels out there with the front center caps, it was a 2x.
The hub is too large in diameter (the cap won't fit around it), and the grease caps stick out too far to allow it to fit flatly. So, you would have to cut a whole in the center of the cap, and cut the flanges off of the cap to get it to sit flush... But then how would you attach it?
Advice: paint the centercaps black and live with it, or get a set of manual hubs.
'97 T100 4x4, 3.4L V6, 220K and counting... Daily driver / hauler
robiewp is offline   Reply With Quote
Old 07-26-2009, 11:55 AM   #3 (permalink)
jv coach's Avatar
Thats what I thought. What size tire did you go with, i was thinking about using the stock FJ size.
Old 07-26-2009, 12:15 PM   #4 (permalink)
robiewp's Avatar
I have the stock FJ size - actually, I have the stock FJ dunlops (265 70 R17). I bought 5 wheels & tires as a set of takeoffs with a few hundred miles on them.
The stock FJ tires are 31.6" diameter. I had 265 75 R16s on before I went to the FJ wheels, so this was actually the EXACT same final size as what I ran before.
It's a smidgeon taller than the original 265 70 R16s "bigger" tires the T100 came with, but mine drives and tows just fine.
Much larger and I think you might want to gear down.
Here's a super-handy tire size calculator.
http://www.miata.net/garage/tirecalc.html
Old 08-20-2009, 11:34 PM   #5 (permalink)
View JOMENTUM1's Photo Gallery
35x12.50x17's
www.4crawler.com balljoint spacers
rub the frame a little when turned sharp
that was before I sassed it
After Sas:
JOMENTUM1 is offline   Reply With Quote
Old 08-23-2009, 10:39 PM   #6 (permalink)
jv coach's Avatar
Thanks for the pics. I found some stock tacoma tires on CL for 80 bucks, so thats what I'm going with.
Old 05-03-2010, 11:29 PM   #7 (permalink)
View hink10's Photo Gallery
Coach/Robiewp, just curious were you able to find a cap to fit the FJ rims or did you go to manual hubs.Thanks Hink10
hink10 is offline   Reply With Quote
Old 05-04-2010, 01:07 PM   #8 (permalink)
robiewp's Avatar
I just painted the stock hubs black and called it good, though I may go manual some day.
Unfortunately I don't think the stock caps will ever in any way fit the front wheels simply because of the diameter of the hubs not leaving room for the cap attachment.
If you have 2wd, they fit fine.
Cheers,
Rob
The Following User Says Thank You to robiewp For This Useful Post:
hink10 (05-05-2010)
Old 05-05-2010, 01:24 PM   #9 (permalink)
jv coach's Avatar
couldnt find a cap and didnt go manual. I painted the hub black.
The Following User Says Thank You to jv coach For This Useful Post:
hink10 (05-05-2010)
Old 05-05-2010, 08:57 PM   #10 (permalink)
Thanks for the reply, I have seen some on craigslist and wanted to know how they worked out for you. The pics of your truck looks great with these rims. thanks again for the info. Hink10
Old 05-05-2010, 10:08 PM   #11 (permalink)
T100 Road Warrior...
BamZipPow's Avatar
Gameroom cash: $762910
View BamZipPow's Photo Gallery
Click the "Thanks" button...
1998 T-100 SR5 2WD auto, Roadmaster Active Suspension, 6½" dropped front air dam, 4½" drop full belly pan, 4° rear diffuser, 11" side skirts, oil catch jar, AC mod, roof ducktail, aero cap, full grill block
Originally Posted by n c t t o r a
You have used a censored word. Please remove this word.
BamZipPow is online now   Reply With Quote
Old 05-06-2010, 11:53 PM   #12 (permalink)
View kenyont's Photo Gallery
I have Fj rims as well, and i just ended up using my old stock caps. see the Proud owner thread to see how they look.
kenyont is offline   Reply With Quote
Old 06-28-2010, 12:04 PM   #13 (permalink)
Found these hub covers on e-bay They do fit,have'nt come off so far, 4 1/4" across.Purchaced from private party so that won't help finding them but they will work on the 17" Fj rims.<a href="http://s916.photobucket.com/albums/ad7/hink10/?action=view&current=P1020091.jpg" target="_blank"><img src="http://i916.photobucket.com/albums/ad7/hink10/P1020091.jpg" border="0" alt="Photobucket"></a>
Old 06-28-2010, 12:09 PM   #14 (permalink)
Sorry have"nt got photobucket down yet.
The Following User Says Thank You to hink10 For This Useful Post:
BamZipPow (06-28-2010)
Old 06-28-2010, 03:55 PM   #15 (permalink)
BamZipPow's Avatar
How do you have those attached/mounted?
The Following User Says Thank You to BamZipPow For This Useful Post:
hink10 (06-28-2010)
