Automatic problems
1994 T-100 4x4 with auto. I guess it is a 4-sp but it sure acts like a 5. Maybe a 4-sp with o/d? Anyhow, the problem is this. In o/d, the whole truck vibrates. It's almost like I lost a couple of cylinders and it runs REALLY rough. If I shift out of overdrive it drives fine. Doesn't matter if you're on the gas or off (not like a u-joint) it almost always does it. Seems to smooth out at 70+. Trans fluid needs changing; dark and smelly...truck was overheated by previous owner. Rebuilt heads, new H2O pump, head gaskets etc...love the rig but wish it didn't have this issue. Definately do NOT want to rebuild the trans. Think just changing the fluid will do it or is there a converter lockup issue or ?
