Clutch slave or master cylinder? - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > T-100
T-100 Discussion forum for the short-lived but extremely popular Toyota T-100 model.
Old 07-31-2009, 09:31 PM   #1 (permalink)
View nikh713's Photo Gallery
how can you if its either? i can pump the clutch to and get pressure to shift. but if i push it in and leave it. it slowly looses pressure.
when i was bleeding the slave i had my wife pump the clutch and hold it down.. then i noticed if u wait a second or two the clutch fork pushes the slave back in even though the pedal is still down.
i dont think it's loosing any fluid anywhere. but maybe its in the boot i'll have to pull the boot off and check.
nikh713 is offline   Reply With Quote
Old 07-31-2009, 09:36 PM   #2 (permalink)
T100 owner for 11 years!
View Vegeta SS4's Photo Gallery
you should be able to buy rebuild kits for both parts from Napa. and it is very easy to do and alot cheaper then buying new ones. done it a couple time on a few trucks .but i have found it is best to both at the same time or when you fix just one it leads to the failure or the other shortly there after .good luck man
Vegeta SS4 is offline   Reply With Quote
Old 07-31-2009, 11:51 PM   #3 (permalink)
out on bail
fourwd1's Avatar
Gameroom cash: $547055
View fourwd1's Photo Gallery
That's a typical sign of an internal leak in the MC, brake or clutch.
SEARCH before asking
84 4Runner rockcrawler - ARBed 5.29's, 36" TSLs, dual t-cases w/ 4.7 crawler gear, Chevys, 30 spline Marlins
83 p/u trail rig - Buick 231 V6, Weiand intake, Holley 4 bbl, TH-350 auto w/700R4 low gearset, dual tanks ...
89 4Runner - stock
http://www.cardomain.com/id/fourwd1
fourwd1 is offline   Reply With Quote
