Dashboard lights - Toyota Nation Forum : Toyota Car and Truck Forums
Wheel & Tire Center
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > T-100
T-100 Discussion forum for the short-lived but extremely popular Toyota T-100 model.
Old 07-06-2010, 02:53 PM   #1 (permalink)
new technician
jjk029's Avatar
View jjk029's Photo Gallery
Dashboard lights
My dashboard lights dont light up when i turn on my headlights. I'm not sure what could cause this. the rheostat knob has been swept and it doesnt do anything. ive gotten like 2 warnings for speeding because i couldnt see the speed. any help would be appreciated.
1995 Toyota T100 SR5 4WD 5 speed 5VZ-FE Custom exhaust
55w Bi-xenon h4 Hids
LT235/85/16 General Ameritrac (?)
BMW 535i heated leather bucket seats
jjk029 is offline   Reply With Quote
Old 07-06-2010, 03:03 PM   #2 (permalink)
T100 Road Warrior...
BamZipPow's Avatar
Gameroom cash: $1449110
View BamZipPow's Photo Gallery
Did you check yer fuses...in particular the 10A Gauges fuse?
If the fuses check good...you'll need to check fer power to the dimmer switch before and after.
1998 T-100 SR5 2WD auto, Roadmaster Active suspension, oil catch jar, AC mod, aero cap, lower aero package, 67% grill block
BamZipPow is offline   Reply With Quote
The Following User Says Thank You to BamZipPow For This Useful Post:
jjk029 (07-06-2010)
Old 07-06-2010, 03:08 PM   #3 (permalink)
new technician
jjk029's Avatar
how do i check the dimmer switch for power, like do you have a diagram of which two terminals i should check?
Old 07-06-2010, 04:41 PM   #4 (permalink)
BamZipPow's Avatar
Wink
If you have physically and electrically checked the fuse, then pull the plug that goes to the dimmer. Use yer multimeter on the plug one wire at a time. Put the other probe to ground. You should see 12V on one of the wires. I'd look it up on my electrical wiring diagram but I'm in the middle of redoing my air ducting.
If you don't see 12V...you'll need to check those fuses again.
Old 07-16-2010, 02:06 PM   #5 (permalink)
new technician
jjk029's Avatar
okay, so i do have full power to the dimmer switch, i checked the resistance while rotating the knob, and it read a constant 18M-ohms so i think it's safe to say i need a new dimmer switch. is this correct?
Old 07-16-2010, 02:11 PM   #6 (permalink)
BamZipPow's Avatar
Yup...
You should be able to use one from a 4Runner as well...
jjk029 (07-16-2010)
Old 07-16-2010, 02:18 PM   #7 (permalink)
BamZipPow's Avatar
Talking
Looking up the part on www.toyodiy.com the part number is 84119-32090.
Looking up that part number on www.toyotapartsales.com I came up with this...and you can see what vehicle you can git the same dimmer rheostat from (parts yard near you).
Mechanical Catalog
Item Number MSRP Core Price Price
8411932090 $129.21 $0.00 $93.22
Electrical - Chassis electrical - Switches - Instrument light rheostat
Instrument light rheostat, camry, w/o digital 1991
Add to Cart Contact Us
Instrument light rheostat, corolla, sedan, wagon, jpp 1991 - 1992
Instrument light rheostat, corolla, sedan, wagon, usa 1991 - 1992
Instrument light rheostat, celica, w/digital speedo 1989
Instrument light rheostat, pick-up 1992 - 1994
Instrument light rheostat, 4-runner 1992 - 1994
Instrument light rheostat, t100, auto trans 1993 - 1994
Instrument light rheostat, camry, w/o digital speedo 1989 - 1990
Instrument light rheostat, corolla, jpp 1989 - 1990
Instrument light rheostat, corolla, usa 1990
Instrument light rheostat, pick-up 1995
Instrument light rheostat, 4-runner 1995 - 2002
Instrument light rheostat, t100, manual trans, w/tachometer, w/power pkg. 1997 - 1998
Instrument light rheostat, t100, auto trans 1995 - 1998
Instrument light rheostat, tacoma, manual trans, w/tachometer, w/sr5 1995 - 2000
Instrument light rheostat, tacoma, manual trans, w/tachometer, all 2001 - 2004
Instrument light rheostat, tacoma, auto trans 1995 - 2000
Instrument light rheostat, tundra 2000 - 2006
jjk029 (07-16-2010)
Old 07-16-2010, 10:50 PM   #8 (permalink)
new technician
jjk029's Avatar
wow, that part is expensive! is there i could possibly fab one with a rheostat from radioshack or does anyone on here possibly have an extra one i could have?
Old 07-16-2010, 11:03 PM   #9 (permalink)
BamZipPow's Avatar
Wink
Yer best bet is to just raid a local parts yard. You could probably walk out of there fer less than $10 fer that part.
I listed all the other vehicles so you know which ones to raid...
Old 07-16-2010, 11:27 PM   #10 (permalink)
Soylent Green sales
fourwd1's Avatar
Gameroom cash: $894955
View fourwd1's Photo Gallery
Not likely. The dimmer rheostat rarely fails.
You say "My dashboard lights dont light up when i turn on my headlights"
but how about the back lights for the radio and HVAC controls, etc, do they work?
If so, probably not the dimmer rheostat. If it's confined to the gauge cluster it's more likely a bad ground to it. Just something to check out.
SEARCH before asking
84 4Runner rockcrawler - ARBed 5.29's, 36" TSLs, dual t-cases w/ 4.7 crawler gear, Chevys, 30 spline Marlins
83 p/u trail rig - Buick 231 V6, Weiand intake, Holley 4 bbl, TH-350 auto w/700R4 low gearset, dual tanks ...
89 4Runner - stock
http://www.cardomain.com/id/fourwd1
fourwd1 is offline   Reply With Quote
Old 07-17-2010, 08:37 PM   #11 (permalink)
new technician
jjk029's Avatar
i just checked, and my HVAC doesn't light up, but my aftermarket radio and amp do, if that constitutes to anything. i'll probably head to a salvage yard sometime within the week, and if anyone in the baltimore area is heading there, haha, let me know! :p
Old 07-18-2010, 04:13 AM   #12 (permalink)
BamZipPow's Avatar
Wink
You can pull the HVAC switch out with yer finger tips. Just swap it out with one from the yard...
Old 07-20-2010, 07:25 PM   #13 (permalink)
new technician
jjk029's Avatar
did you mean the a/c switch Bam?
Old 07-20-2010, 08:08 PM   #14 (permalink)
BamZipPow's Avatar
Wink
Yes...I did. Try it. You can pull it out with yer fingertip/fingernails.
Old 07-20-2010, 08:17 PM   #15 (permalink)
new technician
jjk029's Avatar
haha my a/c switch works perfectly! , but a lack of freon is the culprit for that :p. tomorrow around noonish i should be at crazy ray's on rt40 away from the city :p
Powered by vBulletin® Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
