T100 4WD Won't Engage - Toyota Nation Forum : Toyota Car and Truck Forums
T-100 Discussion forum for the short-lived but extremely popular Toyota T-100 model.
#1 Old 01-10-2011, 09:40 PM
Quoted: 0 Post(s)
(Thread Starter)
1995 T100 Ext Cab 4WD 5 Speed Manual - 4WD shifter won't shift into 4H or 4L. Will move a little. Run fine now in 2H. Suggestions?
EastTN is offline
#2 Old 01-10-2011, 10:43 PM
US Navy Sailor
Quoted: 0 Post(s)
make sure the clutch pedal is depressed all the way, and the shifter in neutral. depending on how often you use it, might have to "force" it into 4hi. sometimes the shift fork doesn't align the gears completely and its sticks.
usnavytaco is offline
#3 Old 01-11-2011, 02:22 PM
Quoted: 0 Post(s)
You should also check out the vacum lines and the cylinoids im having the same problem with mine and thats what i believe it is.
Wess7 is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > T-100
Tags
4wd , t100
User Tag List
Linear Mode Linear Mode
