help with replacing ignition coil. - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > T-100
T-100 Discussion forum for the short-lived but extremely popular Toyota T-100 model.
Old 12-13-2012, 06:20 PM   #1 (permalink)
Gameroom cash: $281100
View Bstylz's Photo Gallery
can someone please point me to the right direction to replace my ignition coil on 97 t-100.
please and thank you.
Bstylz is online now   Reply With Quote
Old 12-13-2012, 11:27 PM   #2 (permalink)
T100 Road Warrior...
BamZipPow's Avatar
Gameroom cash: $1184410
View BamZipPow's Photo Gallery
Wink
2WD or 4WD? 4 or 6 cylinder?
On the 5vzfe engine (V6), are you asking about the Ignitor or Coil on Plug? What is the problem that points you to replacing this part?
On the 5vzfe engine (V6), the COP is easily removed by loosening the 10mm bolt located on the top of the COP. Disconnect the spark plug wire going to the left side of the engine and then the signal harness connector. The COP should easily pull up out of the spark plug tube. If it doesn't, you might need to twist the COP left/right to break it free from the spark plug.
On the 5vzfe engine (V6), the ignitor should be located on the right fender. Disconnect the wiring harness and remove the two fasteners to remove the ignitor.
1998 T-100 SR5 2WD auto, Roadmaster Active suspension, oil catch jar, AC mod, aero cap, lower aero package, 67% grill block
BamZipPow is offline   Reply With Quote
Old 12-14-2012, 12:23 AM   #3 (permalink)
2wd 6 cylinder.
I replace the spark plugs and wires.
Turned on car idled below 1000.
Put to reverse and I hear little boooms...checked all wires and plugs...looks all fine.
Please help
I don't think I put the wires wrong..
Sent from my HTC Sensation XE with Beats Audio Z715e using AutoGuide.Com Free App
Old 12-14-2012, 12:33 AM   #4 (permalink)
BamZipPow's Avatar
Wink
2wd 6 cylinder.
Please help
Check out my spark plug thread and report back with yer findings...
Replacing spark plugs (5vzfe)...
Old 12-14-2012, 12:50 AM   #5 (permalink)
Ya I did everything right...:/
Old 12-14-2012, 12:59 AM   #6 (permalink)
BamZipPow's Avatar
Shoot some video of the problem and post it up.
Did it do this before you changed out the plugs and wires? Is the check engine light on? Did you pull any codes? If so, what were the codes?
What other maintenance was performed prior to this situation? Any other issues that might give us some clues?
Old 12-14-2012, 02:01 AM   #7 (permalink)
Actually I think I connected the wires wrong .
I looked at your diagram again and it looked weird.
I connected the wires like this
1_1
2_2
3_3
Front engine.
So I must of have put them wrong
Why r they so mixed up like your diagram ? Weird placements..
Old 12-14-2012, 02:52 AM   #8 (permalink)
BamZipPow's Avatar
Wink
1_1
2_2
3_3
Front engine.
Yes...you have them hooked up wrong.
Odd numbered cylinders have the COP while the even numbered cylinders have the wires with the #1 cylinder at the front of the engine. I noticed that the wire hook up is always a difference of 3. 1-4, 3-6, and 5-2. Easy way to remember it.
I didn't design the engine or the diagram. I'm just going with what has been proven to work.
Old 12-14-2012, 11:24 AM   #9 (permalink)
Put the wires to the right places and now seems to be good
I can't tell how much I appriciate your help and quick replies.
Thank you so much.
