Installing Fog Lights - Toyota Nation Forum : Toyota Car and Truck Forums
2nd Generation (2005-2015) Discussion area for the 2nd generation of the Toyota Tacoma
post #1 of 31 Old 03-11-2007, 06:10 PM Thread Starter
silvertacoma999's Avatar
Quoted: 1 Post(s)
(Thread Starter)
Hi,
Does anyone have a site/physical location that they purchased genuine toyota fog lights(for tacoma)? Price?
If so, how hard were they to install yourself?
J
It really pissed me off that the SR5 2 Package says that it comes with foglights, but only on a V6. what the hell difference does it make on why they would exclude them from the I 4?
silvertacoma999 is offline
post #2 of 31 Old 03-11-2007, 06:12 PM
Quoted: 0 Post(s)
Tacobama is offline
post #3 of 31 Old 03-11-2007, 06:59 PM Thread Starter
Quoted: 1 Post(s)
(Thread Starter)
wow those arent cheap! but i rather have factory ones as opposed to some generic knock off.
post #4 of 31 Old 03-11-2007, 07:13 PM
Quoted: 0 Post(s)
The kit is easy enough to install. The relay/socket is aftermarket but everything else is oem.
Tacobama is offline
post #5 of 31 Old 03-11-2007, 08:22 PM
'06 Access 4x4 I4 Manual
Quoted: 0 Post(s)
Not hard at all. For a quick overview, check out http://www.yourtacoma.com/faq/ and click on "2005-2006 Tacoma Fog light install" (not the fog light mod one). This is a good start, but I did a lot of things differently since then. mhadden and I were going through this at the same time and I copied some things off of his install.
Differences off the top of my head from the DIY linked above:
- I put the switch in the OEM spot (upper left)
- I tapped switch illumination from the unused Auto-LSD connecter behind one of the other switch blanks in upper panel
- Don't buy a separate wiring harness - just make your own (the factory package above does not come with a wiring harness)
- Wire loom is your friend
- I had to change from the parking lamp relay tap shown to the low beam fuse to pass PA state inspection. You can pick from many places to tap depending on how you want them to work (like the fog light mod or not)
There are lots of people here that either added the OEM's, aftermarket, or both, so ask any questions while you are waiting for delivery of the lamps!
2006 Tacoma 4x4 I4 access cab
http://www.cardomain.com/ride/2430812
TacoCamry0605 is offline
post #6 of 31 Old 03-11-2007, 08:36 PM Thread Starter
Quoted: 1 Post(s)
(Thread Starter)
great site that will be very handy so i dont screw it up! by the way how much did you pay for you're kit?
post #7 of 31 Old 03-11-2007, 08:40 PM
Quoted: 0 Post(s)
I paid $350 +/- for the kit linked above at toyotapart.com.
post #8 of 31 Old 03-11-2007, 08:46 PM
Quoted: 0 Post(s)
TC0605 --
Very similar installation to yours. I powered and grounded everything from the factory locations using the Toyota wiring drawings. I even installed the relay in the engine room J/B. It probably took me twice as long to do it this way, but no one but me would ever know it didn't come from the factory this way.
Tacobama is offline
post #9 of 31 Old 04-14-2007, 03:00 AM
What is this!?
BlkDCabTaco's Avatar
Quoted: 0 Post(s)
I'm going to help my friend install his fog lights. I read http://www.yourtacoma.com/faq/index....d=3&artlang=en and the installation seems easy. I have a problem though. My friend just bought the housing and bulb. We're picking it up tomorrow and i have no clue if it comes with the connector (the thing that connects the harness to the bulb) but yeah any tips will help.
btw where would i get the other stuff like a relay and the fuse holder thing?
and where can i get a wire loom. I have radioshack ones but they're short and expensive =/
06 Black Sand Pearl Double Cab TRD Sport Long Bed
BlkDCabTaco is offline
post #10 of 31 Old 04-14-2007, 06:59 AM
Quoted: 0 Post(s)
Stopped and warned for fogs at night!
My fogs were just shipped from toyotapart.com... The install on the above mentioned site is pretty straight forward. I will be following tacobama's (factory) install...
good luck and take your time! Do NOT be in a hurry!
barkerboy is offline
post #11 of 31 Old 04-14-2007, 08:36 AM
CasaTaco's Avatar
Quoted: 0 Post(s)
I bought my OE style fog lamps on ebay from these folks. They are exactly the correct ones, but all you get is the fog lamps and bulbs.
http://cgi.ebay.com/ebaymotors/ws/eB...8153&rd=1&rd=1
I used the wiring harness from another set of fog lamps that I bought on ebay which don't fit from these guys.
http://cgi.ebay.com/ebaymotors/ws/eB...2512&rd=1&rd=1
Then I bought the OE switch and put it all together and wala - fog lights.
CasaTaco is offline
post #12 of 31 Old 04-14-2007, 10:32 AM
What is this!?
Quoted: 0 Post(s)
i think i will make my own wiring harness but i need info on such as gauge size for the wires, where to get this relay, and the fuse thing and the bubl connectors since i don't think it will be comming with the housing. Oh and that black tape that can take a beating. I dont think it's electrical tape but not 100% sure. Sorry for sounding like a noob but i want everything to be perfect.
post #13 of 31 Old 04-14-2007, 05:25 PM
What is this!?
Quoted: 0 Post(s)
Ok i'm just missing the fuse thing and the connectors. but i need help. the diagrams show that you have to wire the ground to the headlamps themselves but i have no clue on what to do
post #14 of 31 Old 04-15-2007, 07:56 PM
What is this!?
Quoted: 0 Post(s)
I would like to thank PB and Tacobama for answering my many questions about grounding.
post #15 of 31 Old 04-15-2007, 08:06 PM
Quoted: 0 Post(s)
I can see the fog comin!
BlkDCabTaco - looks good! How long did it take you?
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Tacoma Forum > 2nd Generation (2005-2015)
User Tag List
Linear Mode Linear Mode
« Back
