Negative Battery Cable Replacement? - Page 2 - Toyota Nation Forum : Toyota Car and Truck Forums
2nd Generation (2005-2015) Discussion area for the 2nd generation of the Toyota Tacoma
post #16 of 21 Old 08-13-2007, 09:02 PM
Stupid is stupid does
lotust's Avatar
Quoted: 2 Post(s)
Originally Posted by jdwilson
put some coke on it and not cocaine, coca cola. i'm serious. it will eat the corrosion off, then just spray it off with a hose.
+1 mythbusters tesated
295/65/18 Goodyear Duratracs:2.5" lift in the front with 1" rear Block
JBA single exhaust:HID's W/Led's inside:Nfabs
E&G grill insert:ARE Z topper:Overhead DVD for my son:Front DVD for me
lotust is offline
post #17 of 21 Old 08-13-2007, 09:05 PM
Go Sharks!!!
SJlittlefoot's Avatar
Quoted: 0 Post(s)
yea mythbusters also proved, plain water works just as well. But it couldn't hurt to use coke, just make sure you wash it out good.
06 Tacoma D-cab Prerunner TRD Off-Road
http://www.cardomain.com/ride/2284057
SJlittlefoot is offline
post #18 of 21 Old 08-13-2007, 09:20 PM
Quoted: 0 Post(s)
Too bad there's umpteen number of people still using dielectric grease in the wrong way.
08 Sienna Limited AWD
07 Taco DC TRD OR
MDTRD is offline
post #19 of 21 Old 08-14-2007, 03:58 PM Thread Starter
Quoted: 4 Post(s)
(Thread Starter)
In prison, you mean.
Xander Crews is offline
post #20 of 21 Old 08-14-2007, 04:10 PM
Forumatic Immunity!
docindahouze's Avatar
Quoted: 0 Post(s)
iTrader Score: 9 reviews
UK
negative, they use vaseline. you are a chromosome retard. I thought I'd get your theories, mock them, then embrace my own. The usual.
05 Tacoma DC LB TRD Sport Super White.
"I thought I'd get your theories, mock them, then embrace my own. The usual."-House.
docindahouze is offline
post #21 of 21 Old 08-15-2007, 03:47 PM
Hi-Miler
Quoted: 0 Post(s)
dielectric = neutral
it neither conducts nor insulates
it displaces
proper application means water(h2o)
is deterred
it could also add a measure to preventing
that cakey batt acid residue
usually a direct result of a bad connection
a tight connector does not equal a good connection
as far as brakekleen.....wd40 or anything else
never once did anyone sdsuggest a slathering
with most garage products
[wd40 ruins gun ammo primers also]
a modicum used judiciously is correct
"every miles a memory......."
toy-taco is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Tacoma Forum > 2nd Generation (2005-2015)
User Tag List
Linear Mode Linear Mode
« Back
