Can dealer re-calibrate speedometer? - Toyota Nation Forum : Toyota Car and Truck Forums
2nd Generation (2005-2015) Discussion area for the 2nd generation of the Toyota Tacoma
post #1 of 16 Old 07-25-2009, 10:39 AM Thread Starter
smithjesse's Avatar
Quoted: 0 Post(s)
(Thread Starter)
I have done much searching and can't get an answer. If I put on larger tire can the dealer re-calibrate my speedometer so that it will be accurate if I put on larger tires.
Thanks,
Jesse
smithjesse is offline
post #2 of 16 Old 07-25-2009, 11:31 AM
כל הכבוד לצהל
Holling's Avatar
Quoted: 0 Post(s)
Google is your friend my friend.
6380 Google Hits
You can also call your dealer and ask.
You can look up Speedometer in the yellow pages and find shops that do nothing but RECALIBRATE speedometers and tachometers.
Sorry for the sarcasm, I hate laziness.
Now drop and give me 50.............
Holling
2007 Sequoia Limited
2008 Tacoma Double Cab TRD 4x4
ΜΟΛΩΝ ΛΑΒE
Holling is offline
post #3 of 16 Old 07-25-2009, 11:45 AM
Senior TN Member
dl1027's Avatar
Quoted: 3 Post(s)
Recalibrating the speedometer only fixes half of it. There is also lost torque but may be a gain in highway mpg because of lower rpms. If you regear it will correct everything.
'07 Tacoma Silver DC PR SB SR5 V6 AT TP LSD
dl1027 is offline
post #4 of 16 Old 07-25-2009, 01:16 PM
Senior TN Member
yosh2000's Avatar
Quoted: 0 Post(s)
if you find a third from a previous gen tacoma (4.10 ratio) you will get back to stock cheaply!
Want LEDs swapped in your cluster in Denver (or anywhere for that matter!), see here!
Want an OEM HID retrofit (no PNP crap!), see here!
yosh2000 is offline
post #5 of 16 Old 07-25-2009, 03:09 PM Thread Starter
smithjesse's Avatar
Quoted: 0 Post(s)
(Thread Starter)
Still haven't answered my question. Can a Toyota dealership re-calibrate your speedometer? I know all about horse power/torque loss and rear end ratios. I just want to know if I get bigger tires I can easily take it to the dealership and have it re-calibrated. If not I will just stay with stock size. I want to go to 265/75/r16 from 265/70/r16.
post #6 of 16 Old 07-25-2009, 03:24 PM
Quoted: 3 Post(s)
My guess is no as I've spoke to others who have confronted their dealers about this and received a "deer in the headlights" look in return. That said several companies make converters to make the change and perhaps places like M&R in Saginaw, MI could flash the computer to make the change you need. Good Luck,
Motoretro
motoretro is offline
post #7 of 16 Old 07-25-2009, 05:48 PM
Senior TN Member
Quoted: 35 Post(s)
As far as I know, there's nothing for the dealer to adjust. Toyota calibrates the speedo using an average of all of the wheel/tire sizes available for a given model, and they feel that's close enough. The tolerance given in the service manual is quite broad before Toyota advises replacement of the combination meter.
The speedo specialists use other techniques that aren't specific to the manufacturer.
2016 Highlander Limited Platinum
2015 Tacoma DC SB TRD Sport 4x4
toto is offline
post #8 of 16 Old 07-25-2009, 05:58 PM
Senior TN Member
yosh2000's Avatar
Quoted: 0 Post(s)
Still haven't answered my question. Can a Toyota dealership re-calibrate your speedometer? I just want to know if I get bigger tires I can easily take it to the dealership and have it re-calibrated. I want to go to 265/75/r16 from 265/70/r16.
ok....no, they cannot.
if your just going up from a 70 to 75 series tire you will be fine. thats only a ~3% difference. from what i recall, the speedos have a 3% tolerance anyways, so you'll be fine.
hope that answers your question...
yosh2000 is offline
post #9 of 16 Old 07-25-2009, 08:00 PM Thread Starter
smithjesse's Avatar
Quoted: 0 Post(s)
(Thread Starter)
Thanks for the help
post #10 of 16 Old 07-25-2009, 10:37 PM
Got Snow?
05Moose's Avatar
Quoted: 1046 Post(s)
Geez, no one really told you, but our speedo's read 4 mph fast at highway speeds (speedo reads 69 when doing 65). Going from the stock tire size of 265/70 up to a 265/75 will make your speedo accurate. Others here will confirm. Or just search speedo error and read all the threads.
You can confirm the error yourself by comparing to a vehicle you know is accurate (this is how I first discovered the error) or check it against the roadside radars (and this confirmed mine).
'05 4x4 DC LB SR5 (LSD & Tow Pkg), Timbrens, AAL, 5100s, 12/3/04
Mods: Fog, Map/Dome Light, Illuminated 4wd Selector Switch,
DIY Washable Cabin Air Filter (Moose Filter Mod) | & 2010 Highlander 4WD
05Moose is offline
The Following User Says Thank You to 05Moose For This Useful Post:
289er (01-28-2013)
post #11 of 16 Old 07-26-2009, 08:50 PM
Quoted: 0 Post(s)
www.1010tires.com will give you the exact speedo error for any tire size change you select. It's really great! What I would like to find out is if Toyota/Dealerships can or will deny warranty coverage for anything that could be remotely connected to the change in tire/wheel size. If they do, I would bet there have been hundreds of denied claims because so many Tacoma owners have done some pretty radical tire/wheel size changes. Anyone have any first hand experience with Toyota denying coverage?
Eagle1 is offline
post #12 of 16 Old 07-27-2009, 03:35 AM
Quoted: 0 Post(s)
muisejt is offline
post #13 of 16 Old 07-27-2009, 11:28 AM
Senior TN Member
yosh2000's Avatar
Quoted: 0 Post(s)
have you actually installed this on your truck? i am under the impression from my research on the boards that this programmer does not work on our tacomas?
if it indeed does, please let us know!
yosh2000 is offline
post #14 of 16 Old 07-27-2009, 12:19 PM
p00pernickel
Krookz's Avatar
Quoted: 0 Post(s)
The dealer's cannot re-calibrate the spedo's. Re-gearing will not correct it either, except with 1 exception... read below
Remember the speed is picked up off the ABS from each tire, and averaged together by the ECU. Re-gearing wont change how fast your wheel spins. The ONLY exception to this, is the MT's with the worm gears in the tranny, the speed is picked up there and not at the wheel's sensors. If you have one of these, you can also change the gear size by pulling out the sensor(1 bolt) and putting in a different size gear.
Krookz is offline
post #15 of 16 Old 07-29-2009, 12:56 PM
Quoted: 0 Post(s)
Speedo OK one size up
I went up one size (For TRD package), to 265/75 16; using a GPS, my speedometer is now pretty much dead on, at all speeds. GPS units are so prevalent these days, everybody should be using one if only to check their speedo at a variety of speeds. Handy to know how fast you're really going!!
Check your speedo now; if you're a bit low, you should be good to go for the upgrade in size.
Black Rock Taco is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Tacoma Forum > 2nd Generation (2005-2015)
User Tag List
Linear Mode Linear Mode
Back
