Question about spark plugs for 2007 Tacoma - Toyota Nation Forum : Toyota Car and Truck Forums
2nd Generation (2005-2015) Discussion area for the 2nd generation of the Toyota Tacoma
post #1 of 15 Old 11-10-2009, 11:29 AM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Hello my new friends. I am about to purchase a 2007 Toyota Tacoma TRD sport. THe owner said he just checked with the dealer and they told him that the spark plugs don't need to be changed until 120,000 miles. It has 36,000 on it now. Is this for real...how can that be. Please teach me...thanks.
Deebo is offline
post #2 of 15 Old 11-10-2009, 11:51 AM
This Space For Rent
humanoid's Avatar
Quoted: 557 Post(s)
IIRC Tacos came from the factory with Irridium plugs that have a longer service interval than regular copper tipped plugs. 120K sounds about right. I'm sure someone in the "know" will correct if I'm wrong... which is quite often .
humanoid is offline
post #3 of 15 Old 11-10-2009, 12:00 PM
zetapsi827's Avatar
Quoted: 0 Post(s)
that would be correct. I got the same advice from the dealer for my old explorer. Plugs seem to have a lot longer life now days.
zetapsi827 is offline
post #4 of 15 Old 11-10-2009, 12:11 PM
'Coma Nut
ForTech's Avatar
Quoted: 1 Post(s)
Your owners manual will have that information, but to answer your first question, the V6 Tacoma has copper core plugs that need replacing at 30,000 miles. Four cylinders come with the Iridium plugs.
EDIT:
Here is the answer to your second question:
http://www.tacomaworld.com/forum/tec...e-1-gr-fe.html
2005 Tacoma TRD Off Road 4x4 Access Cab
ForTech is offline
post #5 of 15 Old 11-10-2009, 12:17 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Originally Posted by ForTech View Post
Your owners manual has that information, but to answer your first question, the V6 Tacoma has copper core plugs that need replacing at 30,000 miles. Four cylinders come with the Iridium plugs.
EDIT:
So now you're telling me it should be changed. I'm about to buy this truck used...what should I do. I can replace them myself but I don't want to change them if they don't need changing. I sure all of you have Tacomas here..what should I do. Thanks
Deebo is offline
post #6 of 15 Old 11-10-2009, 12:22 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Just found this:
"The Toyota company suggests that all spark plugs be replaced between 60,000 and 100,000 miles, depending on the use of the vehicle. Toyota Tacoma trucks used for large amounts of towing need their spark plugs to be replaced every 60,000 miles."
http://www.ehow.com/how_4484645_repl...ta-tacoma.html
Who knows lol
Deebo is offline
post #7 of 15 Old 11-10-2009, 12:47 PM
Senior TN Member
dl1027's Avatar
Quoted: 3 Post(s)
I'm dragging my feet, sad to say. I have over 50k miles on the stock plugs. The thing is the engine runs great. MPG is as good as ever. I have not noticed any missing.
I've been trying to find the Denso platinum plugs I saw postings about but I cannot find them anywhere.
'07 Tacoma Silver DC PR SB SR5 V6 AT TP LSD
dl1027 is offline
post #8 of 15 Old 11-10-2009, 01:45 PM
Quoted: 0 Post(s)
If you are trying to buy a V6, then the plugs need to be changed. If it is an I4, then you are good till around 100,000 miles.
tetsuo166 is offline
post #9 of 15 Old 11-10-2009, 04:02 PM
Got Snow?
05Moose's Avatar
Quoted: 1055 Post(s)
That's all you need to know right there!
I didn't change mine the first time until I hit just over 48K miles. No noticeable difference at that time. However, just changed them again at 30K. Plugs looked fine, but it seems to run a little bit better going uphill when the engine is cold (temps in the 30s). That's what made me decide to do it at 30K instead of 50K this time.
'05 4x4 DC LB SR5 (LSD & Tow Pkg), Timbrens, AAL, 5100s, 12/3/04
Mods: Fog, Map/Dome Light, Illuminated 4wd Selector Switch,
DIY Washable Cabin Air Filter (Moose Filter Mod) | & 2010 Highlander 4WD
05Moose is offline
post #10 of 15 Old 11-10-2009, 05:07 PM
'Coma Nut
ForTech's Avatar
Quoted: 1 Post(s)
Just found this:
Who knows lol
You can do what you want - I just gave you the information as it is recommended by Toyota. It isn't a hard DIY, and it certainly isn't expensive either. You're forking out the cash for the truck, so the decision is yours.
ForTech is offline
post #11 of 15 Old 11-11-2009, 02:00 AM
let's kick this pig.
nuckinfuts's Avatar
Quoted: 0 Post(s)
I changed my plugs out last week, took maybe an hour and is really easy. They cost $2.99 each at trdparts4u.com. If $20 and an hour of your time is a game changer you've got bigger issues you need to sort out. It's really not a big deal and if you're torn on changing them, just do it! It can't hurt. I changed them around 35k and now around 68k.
'06 TRD OR, 3" OME w/885's, Dakars, 285/75/16 Toyo M/T's, K&N/AEM Intake, Locker Mod, DT Headers, Empire 02 sim. Shrockworks sliders, SGII, WT Floor liners, other odds & ends
nuckinfuts is offline
post #12 of 15 Old 11-11-2009, 07:37 AM
Quoted: 0 Post(s)
are you guys putting any anti sieze on the threads?
tacomajeff is offline
post #13 of 15 Old 11-11-2009, 08:10 AM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Haha I wasn't saying I wouldn't or didn't want to. Just wanted to know when it's recommened to change em.
Another questions, where is the best place to buy parts like filters, plugs etc. I normally went to autozone with my current 1998 Nissan but don't want to buy cheap stuff now when I'm spending $20k on it. Thanks
Deebo is offline
post #14 of 15 Old 11-11-2009, 10:32 AM
TacomaToad's Avatar
Quoted: 0 Post(s)
In addition to the owners manual, there will also be a small booklet titled "Tacoma Scheduled Maintenance Guide" On page 9 there will be the list of items required for the 30,000 mile maintenance. Changing plugs on a V6 is listed to be done. Ask the owner for that booklet, turn to page 9 and ask him if these items have been done. IF not, knock a few more dollars off the price.
Chuck in Cape Coral
09 Mica Silver, TRD Sport, Dbl cab, short bed Prerunner. To be used for a "Toad" behind my motor home.
TacomaToad is offline
post #15 of 15 Old 11-11-2009, 12:33 PM
Quoted: 0 Post(s)
I go to Orielly's because they sell NGK. You cant go wrong with an NGK plug IMHO.
Just changed my 07 V6 plugs at 43K to NGK Irridiums (sp?) and cost was around $65 for all 6 plugs. The truck idles better and runs smoother. Worth every penny to me. : D
07 V6 PreRunner
Rear Leaf TSB & 1" Front Spacer Lift, BHM, 6000K HID Kit, OEM Fogs w/yellow tint, LED Tail lights, Window Visors, Tri-Fold Toneau Cover, Alpine Head Unit, Schoshe Dash Kit, WeatherTech mats,
ITRacer121 is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Tacoma Forum > 2nd Generation (2005-2015)
User Tag List
Linear Mode Linear Mode
Back
