water sloshing sound behind dash - Toyota Nation Forum : Toyota Car and Truck Forums
2nd Generation (2005-2015) Discussion area for the 2nd generation of the Toyota Tacoma
post #1 of 6 Old 09-15-2010, 11:58 AM Thread Starter
Quoted: 2 Post(s)
(Thread Starter)
Canada water sloshing sound behind dash
anyone come across the sound of sloshing water coming from behind the dash, other side of the firewall.
any idea what it might be ?
nobescare is offline
post #2 of 6 Old 09-15-2010, 12:40 PM
forget about "tsb's"
6shooter's Avatar
Quoted: 1 Post(s)
your AC drain hose is clogged. there's water built up in there sloshing around. clear the hose and it will drain.
6shooter is offline
The Following User Says Thank You to 6shooter For This Useful Post:
nobescare (09-15-2010)
post #3 of 6 Old 09-15-2010, 12:40 PM
20' Daredevil (Ret)
Splicer's Avatar
Quoted: 246 Post(s)
Possibly a cowl drain plugged by leaves etc... should be at the outer edges of the cowl, and drain through the rear of the front fenders.
2005 D-Cab O/R 4x4
Splicer is offline
The Following User Says Thank You to Splicer For This Useful Post:
post #4 of 6 Old 09-15-2010, 01:29 PM
Banned
Quoted: 0 Post(s)
AliRazoR is offline
The Following User Says Thank You to AliRazoR For This Useful Post:
post #5 of 6 Old 09-15-2010, 02:45 PM Thread Starter
Quoted: 2 Post(s)
(Thread Starter)
Canada wow
thanks to everyone for the tips.
i'll get at it tonight.
post #6 of 6 Old 07-23-2011, 06:09 PM
Quoted: 0 Post(s)
I have had sloshing/water running sound under my 05 Camry for 6 months. The sound happens when accellerating after stopping and especially starting off on right turns. The sound is loud enough that passengers hear it and ask what it is. Just this morning I read a blog saying it may be low coolant level. SURE enough the overflow reservoir was dry. (MY BAD). I had some red Toyota coolant in the garage. Put about 1 quart in the overflow bottle and ran the car until hot and topped off the radiator. Drove the car for about 15 mins. NO SOUND! Hope this solves it...
Spockulees is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Tacoma Forum > 2nd Generation (2005-2015)
User Tag List
Linear Mode Linear Mode
Back
