Air Vent Removal? - Toyota Nation Forum : Toyota Car and Truck Forums
2nd Generation (2005-2015) Discussion area for the 2nd generation of the Toyota Tacoma
post #1 of 17 Old 06-19-2011, 10:31 AM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Air Vent Removal?
Has anyone had issues with the air blowing poorly out of the vent just left of the radio? My air is being blocked somehow and I need to pull it off to resolve the issue.
Thx.
msgntsu is offline
post #2 of 17 Old 06-19-2011, 11:44 PM
Synchro
Quoted: 0 Post(s)
I don't have the manuals that show how the air ducts are controlled, but I would guess that they're controlled by cable from the knob on the dash. I'm wondering if the duct is actually plugged or if the flap that directs the air into (or not into) that duct is maybe not working . . . i.e. is the cable still attached at both ends?
Does anyone have a manual that shows how the air duct control works & maybe can shed some light on this?
Peace.
2007 Acab 2.7L 5spd 4WD SR5 Silver Streak stocker
Synchro is offline
post #3 of 17 Old 06-20-2011, 01:32 AM
Senior TN Member
RTFM's Avatar
Quoted: 82 Post(s)
First off, lets start with the basics.
1 - the little roller dial under the vent, is it in the open or closed position. Compare it to the others in the dash. Are they all on the same location (full open). IF so, move on. If not, open it.
2 - You don't want to go disassembling the dash to fix the vents. Looking at the FSM, its like a 80+ step process, removing everything, including the parking brake, to fix the AC system. And most of those 80 steps are references to other parts in the manual, so each is a multi step process.
Good luck, hope for #1
06 DC LB 4x4 Speedway, TRD Sport w/ Tow, JBL w/ Grom to IPod / Aux / BT, Roof Rack, Weathertech bug deflector & floormats, Access LE tonneau, Clifford 10.5x alarm, Homelink Mirror, Ultra Grinder Wheels, Michelin LTX MS2 tires
RTFM is offline
post #4 of 17 Old 06-20-2011, 09:11 AM
Take off, eh!
Dante's Taco's Avatar
Quoted: 0 Post(s)
The Tacoma AC is all digital control of servo motors that open/close dampers as far as I am aware. The damper in question is buried very far back, *behind* the entire dash/instrument cluster/radio etc down by the heater / cooler core. RTFM is very correct, you do not go lightly into that forest (no references to Mr. Gump)
I've had my A/C control cluster off, to steal power from it to do the Lighted 4WD Selector Mod, and there are no cables, only wires.
Just another easy check - when was the last time the cabin air filter checked (assuming you have one i.e. 2006+)
G
06 DC LB S45 4X4: Roll 'N Lock / Philips Xtremes / Cobra CB / AllPro IFS, tranny & T-Case skids,1.25 spacers, 10 pack leafs/ R. diff breather mod / fogs-on mod /Nitto Terra G*******s 265/75/16 / Hakkapeliitta LT studded/ Timbrens / Fox CO + 2.0 resi x4 / YotaFab sliders / Yaesu FT2600
VA6TAC
Highlander LE 2001 (wife's)
Dante's Taco is offline
post #5 of 17 Old 06-20-2011, 10:17 AM
Got Snow?
05Moose's Avatar
Quoted: 1060 Post(s)
Are you comparing it with just the AC on? Or is the problem the same regardless of temp (try it at cold and at hot). I've seen threads where cold air with the AC only would only blow out the driver's side vent when the system needed to be recharged (other vents weren't cold). And is it the same in comparison to the other face vent even if you switch it to foot/face vs face only? Trying to eliminate both AC system and the air mix servo as a cause.
If it truly is something caught in there, have you installed a cabin air filter to prevent the debris from outside clogging the system? (From your join date, I'm guessing you could have an '05 which didn't come with a cabin filter)
'05 4x4 DC LB SR5 (LSD & Tow Pkg), Timbrens, AAL, 5100s, 12/3/04
Mods: Fog, Map/Dome Light, Illuminated 4wd Selector Switch,
DIY Washable Cabin Air Filter (Moose Filter Mod) | & 2010 Highlander 4WD
05Moose is offline
post #6 of 17 Old 06-20-2011, 09:24 PM
Senior TN Member
RTFM's Avatar
Quoted: 82 Post(s)
Slight correction to my post above. The little dial thing under the vent is a directional thing, not an open close thing.
On my other car it was open close. Really.
The two center vents near the radio are supposedly the closest to the cooling coils. The ones near the exterior windows have some longer ducting attached. Maybe you can borrow a fiber optic borescope to look through the vent, and see it you have a squirrel living in there, or all the extra socks that disappeared from your laundry have shown up in there maybe.
RTFM is offline
post #7 of 17 Old 06-20-2011, 11:02 PM
Take off, eh!
Quoted: 0 Post(s)
^ just for my own edification... can you rent a fibre optic borescope from... machine shops? larger autoparts chains etc?
See, I live next door to the girls dorm..
(totally kidding about that last part)
But sorry to the OP I didn't notice your join date of 2005, so if you don't have an air filter, perhaps this is a debris issue, which *might* be actually resolvable without a major dash removal. If you can find offending thing.
To give you an idea of what I mean by you don't want to have to drill down to the heart of the A/C system, look at this post here:
How To: Install a USB Charger/Connection Port in a Factory Blank
See how much he had to remove, just to add a USB cable to a radio?
<shudder>
Geoff
VA6TAC
post #8 of 17 Old 06-21-2011, 09:30 AM
Senior TN Member
RTFM's Avatar
Quoted: 82 Post(s)
http://www.amazon.com/DEWALT-DCT410S1-12-Volt-Inspection-Camera/dp/B0043XX89K/ref=sr_1_2?ie=UTF8&qid=1308662775&sr=8-2
This is probably all that you need to find an obstruction. Quick search didn't find anyone renting near me (not that that would help you anyway)
We use high end ones to look for piping defects at work, but they come with a $15k price tag. Most of the rentals I found are ~$300 for 3 days. Quick check of Al Gore's Interweb turns up a few places.
The low res cheapies will do most of what you need for this, but don't expect to crawl down exhaust manifolds looking for leaks (and finding them)
RTFM is offline
post #9 of 17 Old 06-21-2011, 09:44 AM
Senior TN Member
Dark Taco's Avatar
Quoted: 9 Post(s)
How could I justify this purchase to myself????
'16 4runner TEP
'08 Tacoma Rugged Trail (sold)
Dark Taco is offline
post #10 of 17 Old 06-21-2011, 04:27 PM
Senior TN Member
RTFM's Avatar
Quoted: 82 Post(s)
You need to look for your / your wife's wedding ring, which you / she may have dropped into the wall while installing your latest entertainment center speakers.
You need to see if your (wife/ GF / Daughter) really dropped an earring into the shower drain.
You are trying to find a rattling noise inside the rear seat air vent (on the floor under the driver's seat) Might be a battery / marble / coin that slid inside there.
Its a really cool gadget that you don't know why you need it, but you will need it some day. And this way you won't have to wait for it.
RTFM is offline
post #11 of 17 Old 06-21-2011, 11:56 PM
Take off, eh!
Quoted: 0 Post(s)
Hey, I wonder if could use this to inspect inside valve cover on the 1MZ-Fe 3.0 L Highlander engine.... (looking for sludge)
man that would rock if it would fit past the oil filler damper
G
VA6TAC
post #12 of 17 Old 06-22-2011, 01:52 AM
Senior TN Member
RTFM's Avatar
Quoted: 82 Post(s)
Think the head on this one is too big. The high end ones come in 4mm dia. which may still be too big.
RTFM is offline
post #13 of 17 Old 06-22-2011, 02:07 AM
Take off, eh!
Quoted: 0 Post(s)
OK, I kinda wondered if that would be the case. Sure would beat pulling a valve cover.
Oh well. Guess I'll do it the old way
VA6TAC
post #14 of 17 Old 06-22-2011, 08:23 AM
WetOne's Avatar
Quoted: 0 Post(s)
Dante, The front valve cover comes off easily and will have the worst sluge if you have any. The rear one takes a greater investment in time and patience. Also be prepared to do spark plugs , wires, PCV valve and grommet, spark plug tube seals, and maybe soak valve covers in 5 gal bucket of degeaser to clean before install. I also painted my wifes covers with black epoxy. Dante, check out the thread "Has anyone seafoamed their 4.0 yet" I am the last post in the thread and there is a picture of my wife's 3.0 at 125k miles.
WetOne is offline
post #15 of 17 Old 06-22-2011, 09:09 AM
Take off, eh!
Quoted: 0 Post(s)
Thanks Wetone - found pic - wow you got that nice & clean!
for the OP: any news on... anything? Was yours a 2005 (so no cabin filter)?
G
VA6TAC
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Tacoma Forum > 2nd Generation (2005-2015)
User Tag List
Linear Mode Linear Mode
« Back
