Turning in 4 wheel drive - Toyota Nation Forum : Toyota Car and Truck Forums
2nd Generation (2005-2015) Discussion area for the 2nd generation of the Toyota Tacoma
post #1 of 5 Old 11-19-2011, 11:45 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Hi i just got a 2012 Tacoma about a month ago. when i first drove it i had it in 4-wheel drive and never had an issue with it. but now when its in 4-wheel drive and i turn (not very sharp ether) the truck will jurk and jump hard like its binding. (almost like the diffs are locked but their not) the truck only has like 550 miles on it. is this normal or should i get it checked out and what would cause this to happen?
Thanks
Oldbusthead is offline
post #2 of 5 Old 11-20-2011, 12:31 AM
This Space For Rent
humanoid's Avatar
Quoted: 552 Post(s)
Are you doing it on a paved surface? IIRC you're not supposed to be using the 4wd function on a paved road.
humanoid is offline
post #3 of 5 Old 11-20-2011, 12:31 AM
ALSO AVAILABLE IN SOBER
Zembonez's Avatar
Quoted: 238 Post(s)
Normal operation. Every 4x4 vehicle I ever had would do this. You notice it more in 4 low.
03 Camry - 09 XB - 07 GMC Sierra - 14 Accord Sport
Zembonez is offline
post #4 of 5 Old 11-20-2011, 08:46 AM
Senior TN Member
Quoted: 35 Post(s)
That's normal for part-time 4x4 systems without a center differential (like the Tacoma). Without the center diff, the front wheels and the rear wheels are both being driven at the same speed. But when you turn the front wheels to the side, physics dictates that they cannot turn at the same speed as the rear wheels.
Because of that, you get the binding problem on dry pavement. If the pavement were wet/slippery, the front wheels could slip a little bit and not cause the binding. So, it's best to only use the 4WD modes when necessary due to slick pavement conditions or off-road.
In contrast, vehicles like crossovers with AWD or some SUV's with 4WD have a center diff that mechanically allows the front wheels to turn at a slightly different speed. Then there is no binding at all, and those systems can be driven with power to all 4 wheels all the time. If the center diff can be locked, then locking the center diff would take it out of the equation and then it's just like there is no center diff.
2016 Highlander Limited Platinum
2015 Tacoma DC SB TRD Sport 4x4
toto is offline
post #5 of 5 Old 11-20-2011, 09:22 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Ok thank you =)
yeah im in Alaska and i have been keeping it in 4 wheel most the time because lots of ice and snow on roads......,it was doing it on the snow also thats why i thought it was kinda weird...
also i am used to the Landcruiser w/ the center diff i think that is why i thought it was strange.
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Tacoma Forum > 2nd Generation (2005-2015)
User Tag List
Linear Mode Linear Mode
Back
