Bed twisted? - Page 2 - Toyota Nation Forum : Toyota Car and Truck Forums
2nd Generation (2005-2015) Discussion area for the 2nd generation of the Toyota Tacoma
post #16 of 85 Old 11-21-2012, 11:28 AM
lover of teh boobies
johnecon2001's Avatar
Quoted: 0 Post(s)
With out the truck being on perfectly level ground, suspension sag near or at 0° and tire pressure optimal.... your bubble level didn't tell you anything.
johnecon2001 is offline
post #17 of 85 Old 11-21-2012, 11:34 AM Thread Starter
Do Work!
AndeyHall's Avatar
Quoted: 0 Post(s)
(Thread Starter)
I realized that argument would come up, that's why I took bed rail slopes. No the bed rails may not be level depending on how level the truck sits, but there's no reason they should be at different angles (unless of course the frame is twisting it that way).
And the truck is sitting in a garage on, yes, perfectly level pavement. Checked tire pressure and they are all perfectly at 35psi. And there is absolutely nothing in the truck that would cause the suspension to sag that much on one side. Take this into account that you can obviously see the tailgate at a ridiculous angle compared to the rest if the truck, I'd say the bubbles say quite a bit for themselves.
It's better to be thought of as stupid than to open your mouth and remove all doubt. http://www.cardomain.com/ride/2235368
AndeyHall is offline
post #18 of 85 Old 11-21-2012, 11:44 AM
Senior TN Member
Dark Taco's Avatar
Quoted: 9 Post(s)
Since i'm off work today I went out to the garage and put a level on my bed rails and they were both the same but not perfectly level. Probably due to the factory rake. If you want I can post some pictures for you. But, I don't think that would help you much.
'16 4runner TEP
'08 Tacoma Rugged Trail (sold)
Dark Taco is offline
post #19 of 85 Old 11-21-2012, 11:58 AM Thread Starter
Do Work!
AndeyHall's Avatar
Quoted: 0 Post(s)
(Thread Starter)
Yeah I mean it shouldn't matter what front to rear angle the bed rails are at, unless there is something like frame twist, they should be at the same angle, whatever that angle may be.
Sent from my iPhone using AutoGuide.com App
post #20 of 85 Old 11-21-2012, 12:42 PM
Got Snow?
05Moose's Avatar
Quoted: 1055 Post(s)
I don't think the levels are even necessary. The frame is obviously twisted from the first pic.
'05 4x4 DC LB SR5 (LSD & Tow Pkg), Timbrens, AAL, 5100s, 12/3/04
Mods: Fog, Map/Dome Light, Illuminated 4wd Selector Switch,
DIY Washable Cabin Air Filter (Moose Filter Mod) | & 2010 Highlander 4WD
05Moose is offline
post #21 of 85 Old 11-21-2012, 01:01 PM Thread Starter
Do Work!
AndeyHall's Avatar
Quoted: 0 Post(s)
(Thread Starter)
That's what I say too!
post #22 of 85 Old 11-21-2012, 01:03 PM
20' Daredevil (Ret)
Splicer's Avatar
Quoted: 246 Post(s)
True.... add all the other pics and it's pretty damning evidence.... the frame certainly appears to be tweaked. The body shop should have caught it.
That said, I don't know for a fact whether it can (or should) be properly repaired. I do know that at least in the past, bent frames were routinely straightened. No doubt a lot of factors come into play. While it is noticeable, it doesn't look severe, and it's possible that it could be easily repaired -- I wouldn't rule it out without further investigation.
2005 D-Cab O/R 4x4
Splicer is offline
post #23 of 85 Old 11-21-2012, 01:15 PM Thread Starter
Do Work!
AndeyHall's Avatar
Quoted: 0 Post(s)
(Thread Starter)
Well if I have the option to have it totaled (maybe with a little pressure on insurance of course) or to have it repaired, I'd rather have it totaled. The truck was (and still is) for sale before the wreck. So I don't want to be stuck selling a truck that is potentially half the value of what it as originally. I mean would you buy a truck at full retail, or anywhere close to it if you say it had had frame damage in the past, regardless of whether it not it was "fixed" or not?
post #24 of 85 Old 11-21-2012, 01:29 PM
20' Daredevil (Ret)
Splicer's Avatar
Quoted: 246 Post(s)
^^ Perfectly understandable. I hope it works out for you.
2005 D-Cab O/R 4x4
Splicer is offline
post #25 of 85 Old 11-21-2012, 01:48 PM
Senior TN Member
Dark Taco's Avatar
Quoted: 9 Post(s)
Is this a body shop your insurance company sent you too? Or is it a shop from the insurer of the person who hit you? Also, as I have been sitting here thinking about it, make sure they just don't shim the bed...tell you its fixed and let you walk.
'16 4runner TEP
post #26 of 85 Old 11-21-2012, 01:57 PM Thread Starter
Do Work!
AndeyHall's Avatar
Quoted: 0 Post(s)
(Thread Starter)
It's a shop my insurance sent me to. His insurance didn't have any "approved" shops within an hour away so they just told me to choose the body shop of my or my insurance's choosing. Happened to be that it was the same body shop.
post #27 of 85 Old 11-21-2012, 02:46 PM
Senior TN Member
Dark Taco's Avatar
Quoted: 9 Post(s)
That's a good thing and hopefully only works in your favor.
'16 4runner TEP
post #28 of 85 Old 11-22-2012, 10:02 PM
hickory's Avatar
Quoted: 0 Post(s)
bent frame
Definitely feel for you, best of luck man. The frames on these trucks are nothing like the 250.
The snow is leaving, still a foot
Cooper AT3 work great
hickory is offline
post #29 of 85 Old 11-22-2012, 10:09 PM
ALSO AVAILABLE IN SOBER
Zembonez's Avatar
Quoted: 239 Post(s)
The level is meaningless without the truck on a frame machine and perfectly level.
Originally Posted by AndeyHall View Post
Well I'm taking it back to the shop on Monday but I talked to a friend of mine that's an attorney and he said that if they determine the frame is warped then you can require that they total it. Because realigning a frame is never 100%.
Your friend is talking out of his ass. He's obviously a real collision repair expert.
Aligning a frame is no different than repairing anything else on a vehicle. For some reason people attach "Holy Grail" status to this particular piece of metal. The picture you posted doesn't indicate a "mangled frame". It simply needs to be looked at and corrected.
03 Camry - 09 XB - 07 GMC Sierra - 14 Accord Sport
Zembonez is offline
post #30 of 85 Old 11-23-2012, 12:30 AM Thread Starter
Do Work!
AndeyHall's Avatar
Quoted: 0 Post(s)
(Thread Starter)
No it simply needs to be TOTALED! I'm not gonna be stuck trying to sell a truck with that big of a hit on the carfax.
Which I think proves my point and contradicts yours...those people are referring to my potential buyers.
This usually happens earlier in the thread...the 2nd know it all comes in and claims that the first guy is a know it all and is completely wrong. I must have missed you supplying your credentials that explained to us why you were any more of an expert than he is? And to be honest I don't think he was speaking from a mechanic's standpoint, but rather from an attorney's standpoint representing someone who is going to be stuck with a worthless vehicle because of some other jackass' negligence. And I realize it can happen to anyone including myself, but you can't expect the innocent party to eat the costs.
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Tacoma Forum > 2nd Generation (2005-2015)
User Tag List
Linear Mode Linear Mode
« Back
