Wiper blades - Toyota Nation Forum : Toyota Car and Truck Forums
2nd Generation (2005-2015) Discussion area for the 2nd generation of the Toyota Tacoma
post #1 of 18 Old 11-28-2012, 07:01 PM Thread Starter
edm3rd
Quoted: 5 Post(s)
(Thread Starter)
Wiper blades
Preference on replacement wiper blades ? Ran by AutoZone, Advanced, and O'Reilly's. Only Advance had replacements inserts; the other 2 chains only had full assemblies. All show replacement inserts on their websites.
OEM lasted almost 3 years; Michelin latitudes about 6 months (started chattering).
Any suggestions for both year round ? also for winter ?
TIA
edm3rd is offline
post #2 of 18 Old 11-28-2012, 07:47 PM
Senior TN Member
Dark Taco's Avatar
Quoted: 9 Post(s)
I have had success with the RainX whole blade replacements. I once spent the extra $ on the Bosch blades...wasn't impressed.
'16 4runner TEP
'08 Tacoma Rugged Trail (sold)
Dark Taco is offline
post #3 of 18 Old 11-28-2012, 07:55 PM
20' Daredevil (Ret)
Splicer's Avatar
Quoted: 243 Post(s)
The only ones I have used so far is OEM inserts. IIRC, the originals lasted about 4 years (longer than I expected!). That puts 3 years on the replacements, and I'm about to get new ones -- also OEM replacement inserts. They seem to last pretty well, do a good job, and are not expensive.
2005 D-Cab O/R 4x4
Splicer is offline
post #4 of 18 Old 11-28-2012, 07:59 PM
Quoted: 0 Post(s)
I mostly use the full replacement from Walmart where is the best price for ANCO which I never had problems with them. I prefer to replace them once a year for the best performence.
western88 is offline
post #5 of 18 Old 11-28-2012, 08:47 PM
Quoted: 9 Post(s)
I go for the full blade replacement. The inserts are a PIA! Not that much difference in cost.
If you live in a metro area (Houston, Dallas, Detroit, NY, LA, etc.) the blades won't last long...maybe 6 months. If in a rural area or where there is clean air (where's that???) the blades last much longer. Ozone in the air in the metros is the killer on wiper blades.
ozarkie is offline
post #6 of 18 Old 11-28-2012, 08:58 PM
Senior TN Member
Dark Taco's Avatar
Quoted: 9 Post(s)
Time to move down south into the country!
'16 4runner TEP
post #7 of 18 Old 11-28-2012, 09:41 PM
Quoted: 9 Post(s)
I did!!
ozarkie is offline
post #8 of 18 Old 11-28-2012, 11:06 PM
Quoted: 0 Post(s)
I bought a set of the cheap Bosch full replacements last spring and by fall they were toast. They usually last at least a year so I am not a happy camper. Last week I was at a Les Schwab tire center buying snow chains and it turns out they have full replacements for $7.95 each installed, so that's what I'm running now.
rolandk is offline
post #9 of 18 Old 11-29-2012, 12:05 AM
Got Snow?
05Moose's Avatar
Quoted: 1046 Post(s)
I've said it before and I'll say it again: Bosch wipers suck! (Hopefully that sticks in everyone's heads so they don't get the pleasure of experiencing tons of streaking out of the boxes...all 4 of them for me before I gave up)
If you're considering a beam wiper, stick with Anco. If not, I always prefer the OEM inserts.
'05 4x4 DC LB SR5 (LSD & Tow Pkg), Timbrens, AAL, 5100s, 12/3/04
Mods: Fog, Map/Dome Light, Illuminated 4wd Selector Switch,
DIY Washable Cabin Air Filter (Moose Filter Mod) | & 2010 Highlander 4WD
05Moose is offline
post #10 of 18 Old 11-29-2012, 12:33 AM
Resident Nutcase
sweeneyp's Avatar
Quoted: 1116 Post(s)
I'm mad I threw away my OEM "arms" (is that what they are called??). The OEM inserts are great and last forever (well you get the idea)
Every aftermarket one I've used streaks like crazy after 6 months:
Rain-X Latitude
Rain-X Fusion
Michelin Hybrid Stealth wiper blades
They work great when new, but just don't last. You reallly can't go wrong with OEM. Plus my experience with beam wipers, avoid like the plague... The highlander uses a 26" wiper (not sure what the taco uses), and beams just don't work good on that long of a blade (they don't sit right, or give an even "wipe")
Click Here for the Full List of Mods Done to My Highlander ---->>> 2008 FWD Highlander Limited
sweeneyp is offline
post #11 of 18 Old 11-29-2012, 01:18 AM
20' Daredevil (Ret)
Splicer's Avatar
Quoted: 243 Post(s)
IIRC, Tacoma uses one 21" and one 22".
2005 D-Cab O/R 4x4
Splicer is offline
post #12 of 18 Old 11-29-2012, 09:25 AM
Got Snow?
05Moose's Avatar
Correct. The beam blades work better than hinged wipers IMO for the Taco. I do agree with sweeney for the HL because it has a very flat glass with a very long wiper. I'm sticking with OEM inserts on it (plus it has heated glass and protected hinges for snow unlike the Taco).
05Moose is offline
post #13 of 18 Old 11-29-2012, 11:39 AM
Quoted: 22 Post(s)
I am a fan of the silicone blades based on longevity and the water-beading property. I used the PIAA ones and am getting 5 years out of them, vs 1.5 years for OEM rubber ones.
TurDonor is offline
post #14 of 18 Old 11-29-2012, 11:35 PM
Quoted: 0 Post(s)
x2
The Rain-X Latitude blades cost more than wiper blade refills, but I think they're worth it. I've had mine for several years now and they still work just fine. I live in Wisconsin, so good winter wipers are important to me. What I really like about the Latitude blades is that it's easy to break ice off of them... you can bend the entire blade to crack off the ice, unlike the OEM metal wipers.
PoorInRichfield is offline
post #15 of 18 Old 11-30-2012, 08:28 PM
E-11 blaster rifle
racepauly's Avatar
Quoted: 0 Post(s)
My Costco sells Michelin wiper blades.
Here's a link to the mfg site
http://www.michelinwipers.com/us-home.shtml
I don't know the long term but at 1 month they wipe real nice and look stealth.
Sent from my iPhone using AutoGuide.com App
racepauly is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Tacoma Forum > 2nd Generation (2005-2015)
User Tag List
Linear Mode Linear Mode
Back
