Black headlight Write up 2005's - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Tacoma Forum > 2nd Generation (2005+)
2nd Generation (2005+) Discussion area for the 2nd generation of the Toyota Tacoma
The Gameroom
There is 1 open event in the Betting section.
Old 11-09-2005, 09:44 PM   #1 (permalink)
View 05XRunner's Photo Gallery
Black headlight write up
Here is a quick write up.
It was really easy once you get the headlights apart.
Take the headlights out. You will have remove the grill and that small piece below the lights wich is very easy.
There are 4 bolts for the headlights.
2 up top, 1 at the bottom inside corner bumper hides it a little but u can get it out and the 4th is you gotta go up under. As you see in the pic is where the 4th bolt is
Once the lights are out. Remove everything off of them. All the plastic pieces all the lights and rubber things and 3 hex screws. Make sure not to mess with the adjustment knobs.
I took off the top weather strip but others say you can leave it on.
Cooking the lights.
I found at 305 degrees for 9mins works well. Remember preheat the oven then once you put the light in there turn it off.
At this time and temp it should pry apart the first try. Just take your time and dont rush anything. This is not something that just peels apart super easy. I didnt use any tools. I just used my hands by starting in the one corner where its easy to grab both parts. I also had a buddy helping me pry it apart slowly.
Once apart. Remove the 2 hex screws in the plastic piece in the lens.
Pull it out. pop out the orange marker and the turn signal lens.
I used Krylon Fusion paint. No prep needed its also desinged to Bond to plastic and is pretty strong from what i read.
All I did was take a scotch brite pad and just scuffed it up a little bit just to take a little extra measure. I cleaned it off with glass cleaner. I wore goves so I would not get any oils back on the surface.
Paint away and take your time and dont put on thick coats. It took me 25mins per light to paint it using lighter coats so you dont get any runs or drips.
Let it dry for about 20mins and be careful I still didnt touch the painted surface I carry from behind and be VERY CAREFUL putting markers back in if you choose to do so. The paint is not fully chip resistant for 7days.
After that I put the 2 pieces back in the oven at 300 for 5mins just to get the caulk soft. I also used silicone Window/door to put in the seam of the housing. Then i pressed it back together tightlight. put the hex screws in and popped the tabs in place. After that I put another bead of silicone all the way around the seams again.
Thats it put it back in the truck. Also that 4th bolt that is under SCREW IT. I still havent put it back in and the light does not budge with 3 bolts.
Hope everyone that tries it has a good outcome. Just take your time it took me 4hrs
They will look like this
http://i12.photobucket.com/albums/a2...r/DSCN0349.jpg
http://i12.photobucket.com/albums/a2...r/DSCN0343.jpg
http://i12.photobucket.com/albums/a2...r/DSCN0342.jpg
Custom Exhaust|TRD CAI|URD Short Shifter|Black Headlights|MSR 093 20x8.5 Wheels|Nitto 555 - 255/35/20|DTLT headers|Sittin Sic Street Drop|NST Crank Pulley|Recessed Grill Mod
05XRunner is offline   Reply With Quote
Old 11-09-2005, 10:40 PM   #2 (permalink)
WAX museum.
55reasons's Avatar
View 55reasons's Photo Gallery
Damn bro! What is this like thread number 12 or what?
http://www.tundrasolutions.com/forum...lack+headlight
http://www.toyotanation.com/forum/t105442.html
http://www.toyotanation.com/forum/t105235.html
http://www.toyotanation.com/forum/t105034.html
http://www.customtacos.com/ubbthread...ev=#Post547055
http://www.toyotanation.com/forum/t93275.html
http://www.customtacos.com/ubbthread...6&fpart=1&vc=1
http://www.customtacos.com/ubbthread...&o=186&fpart=1
Originally Posted by kevynb
Oh by the way the Toyota Supra Twin supercharged will kill any slomaro! There is your Toyota
55reasons is offline   Reply With Quote
Old 11-09-2005, 11:06 PM   #3 (permalink)
Cam wanted me to make aseperate thread so he can link it in the DIY sticky
Old 11-12-2005, 04:37 AM   #4 (permalink)
cam2Xrunner's Avatar
Thanks,
I'll leave those links up too in case anyone want's to check them out for ?'s people might have already asked in those threads.
Old 11-12-2005, 05:14 AM   #5 (permalink)
Pb
Surfing TN via iPhone
Pb's Avatar
iTrader Score: 15 reviews
View Pb's Photo Gallery
Originally Posted by cam2Xrunner
Thanks,
Yeah, we wouldn't want people to actually have to use the Search button.
Pb is offline   Reply With Quote
Old 11-12-2005, 06:07 AM   #6 (permalink)
hehe, well there are Customtaco's links in there too, and since 55reasons took the time of looking up those thread, it'd be a shame to delete them.
Old 11-13-2005, 12:07 AM   #7 (permalink)
Smell the Audiophiliacity
LiquidClen's Avatar
View LiquidClen's Photo Gallery
I want to try this, but I am afraid...
LiquidClen is offline   Reply With Quote
Old 11-13-2005, 12:35 AM   #8 (permalink)
Pb
Pb's Avatar
I could do it for ya, but it'll cost ya.
Old 11-13-2005, 12:42 AM   #9 (permalink)
LiquidClen's Avatar
How much?
Old 11-13-2005, 12:48 AM   #10 (permalink)
Pb
Pb's Avatar
I did it for this other dude for $180 total. $150 labor and then $30 for supplies and return shipping.
Might sound a little steep, but time is money. Any less than that and I'll just go back to work and do some overtime for $35 an hour.
Old 11-13-2005, 12:48 AM   #11 (permalink)
thats stupid...Save your money..Do it yourself it isnt hard at all. Just time consuming..If you had someone else do it would take 1000x as long.
Just do it. The hardest part is doing that first light in the oven to get it apart. After you get that first one apart. Its cake. Just follow my write up and do not forget to heat both peices back up at 300degrees for a few mins to get that glue soft again so u can press it together and seal it up
Old 11-13-2005, 12:49 AM   #12 (permalink)
WOW...that guy was dumb...I woulda did that for someone for 50bucks. You really ripped him off
Old 11-13-2005, 12:49 AM   #13 (permalink)
LiquidClen's Avatar
Maybe in a few weeks
Old 11-13-2005, 12:50 AM   #14 (permalink)
Pb
Pb's Avatar
Yeah, really it would just be easier to do it yourself.
Just snug up your balls and go for it.
Take your time and let the paint dry good before re-assembly.
Old 11-13-2005, 12:00 PM   #15 (permalink)
MODIFICATIONS MUST B MADE
JUNGLEMAN's Avatar
View JUNGLEMAN's Photo Gallery
sooooooo..............
satin or gloss??
I see it comes in navy maybe I could use that and then mist black over it to get close to indigo
JUNGLEMAN is offline   Reply With Quote
