Glove Box Shock Attachment Point... - Toyota Nation Forum : Toyota Car and Truck Forums
2nd Generation (2005+) Discussion area for the 2nd generation of the Toyota Tacoma
#1 Old 02-04-2006, 10:47 AM
TacoSport05's Avatar
Quoted: 0 Post(s)
(Thread Starter)
Thumbs down Glove Box Shock Attachment Point...
...Is a Piece of Sh!t! So I finally decided to put a cabin air filter in the HVAC unit located behind the glove box. (Toyota again trying to save money on the '05's while they charge premium dollar for a truck...came to their senses though for the '06 and made it standard...)In order to get to it, you need to detach the shock (dampens the glove box when you open it) from the right side. Well, I did that and put in the air filter, and re-attached the shock but now the damn thing keeps coming detached!!! There is a plastic stud that's molded into the lower dash. This stud is what the shock snaps onto. Well, now the shock just keeps popping off. Everytime I open the glove box with a CD case, the shock just pops off and the glove box slams down. Looks like the only way to replace this plastic stud is to replace the whole dash!!
TacoSport05 is offline
#2 Old 02-04-2006, 11:06 AM
PSU TACO
Plow78's Avatar
Quoted: 0 Post(s)
I feel your anger mine is still off and I cannot get it to go back on without falling back off!
2005 Silver Mica Tacoma Access Cab TRD 4x4, Package #2 (w/ scooped hood )
Matching front window tint, Truxedo Lo-Profile Tonneau
Toyota Step Bars & Bed Mat,
AVS In Channel Rain Guards, Weathertech Floor Liners
Sirius Sportster w/Ant. thru 3rd Brake Light
Plow78 is offline
#3 Old 02-04-2006, 11:09 AM
Quoted: 0 Post(s)
(Thread Starter)
Looking at that plastic stud that the shock mounts to, there is a slot in the middle of it. I am gonna try and put a small zip tie through the middle of it. That way, the damn thing won't slip in-board and off. I'll see if this works and post any results.
#4 Old 02-04-2006, 11:51 AM
koa
Quoted: 0 Post(s)
I jammed a little papper in the slot until I figure out something better. I think the dealer should cover this under warranty and replace the whole panel. I wonder if 06 is any better?
koa is offline
#5 Old 02-04-2006, 11:57 AM
Pb
Surfing TN via iPhone
Pb's Avatar
Quoted: 0 Post(s)
iTrader Score: 15 reviews
Use a screw driver to spread the little nub apart. This should make it fit tighter, Unless you have really goobered it up and fatigued the plastic.
Pb is offline
#6 Old 02-04-2006, 02:48 PM
Quoted: 0 Post(s)
Good news group, I have the same issue with my 06 Prerunner. After checking the filter the shock mount will no longer hold. At the first service I mentioned it in passing to the service adviser and he walk right in the office and ordered a whole new dash! The dash just came in and I have an appointment this week to work on it. I may even get a rental if it takes over a day to do! It looks like it was manufactured with a sag in the tab. I debated on whether to have the whole dash replaced or just use the heat gun to soften and straighten tab. It was a hard choice because I wonder if they will be able to get it back together as good as it was because rattles drive me CRAZY!
I will report back once the job is done.
Shane
06 Prerunner with some options........
TacoMan55 is offline
#7 Old 02-04-2006, 10:01 PM
Quoted: 0 Post(s)
that thing is a total POS.
What I did was to drill a small hole into the middle of the plastic nub.
I then ran a small self tapping sheet metal screw into the middle of the nub from the end.
It spreads the tabs apart and will expand them enough and still be able to put the shock absorber over the tabs. It works pretty good and maybe better than having the entire dash replaced.
Good luck with yours tacoman. Let us know how it goes for ya.
Later
05 Indigo Ink Double Cab Sport 4x4 V-6 Auto Long Bed.
IndigoTaco05 is offline
#8 Old 02-04-2006, 10:12 PM
HANG UP AND DRIVE!!!
nomad's Avatar
Quoted: 0 Post(s)
I bet the engineer that designed that part got a "D" on their final project in college.
Reminds me of a joke... What do you call a student that graduated last in their class at medical school???
.... Doctor
nomad is offline
#9 Old 02-04-2006, 10:15 PM
Quoted: 0 Post(s)
Later
I know its a pain in the ass, but do you think you could take a photo?
Slate Metallic Grey 2008 Toyota Tundra CrewMax SR5 4x4 5.7L V8
6" ProComp Suspension Lift
20" wheels w/ 35x12.50 Toyo Open Country M/T Tires
Flowmaster 50-series Dual Exhaust
trruuck is offline
#10 Old 02-04-2006, 10:38 PM
Quoted: 0 Post(s)
I will see If I can get one. I just hate taking that piece of shit apart any more than I have too. As you guys know every time you pull that shock off is one step closer to the POS breaking off completely.
Later
#11 Old 02-04-2006, 11:44 PM
Smell the Audiophiliacity
LiquidClen's Avatar
Quoted: 0 Post(s)
I had my glove fiberglassed to fit an 8" woofer and suffer from the same problem. I'm going to the dealer Monday for an oil change and to buy some fuses, should I mention it?
LiquidClen is offline
#12 Old 02-05-2006, 01:08 AM
05 Silver Sport TRD
tacokahitas's Avatar
Quoted: 0 Post(s)
my 2 cents
I know what you guys mean especially if not being careful enough around plastic pieces to break! Here's what I did and hope this help to fellow tacoma owner's! Basically I just cut the back of the glove box so I don't have to deal with popping the glove box every time to get to the filter!
Note the filter door is open here, a little tight, but able to get to the tabs!
Here's the door closed, I probably should have cut a little more for easier access, all well, good enough! Good luck!
http://www.cardomain.com/ride/814506/2
tacokahitas is offline
#13 Old 02-05-2006, 02:11 AM
Banned
turbos17's Avatar
Quoted: 0 Post(s)
Dude why did you cutt your glove box? It is very easy to take it off and on without having to cutt it!
turbos17 is offline
#14 Old 02-05-2006, 02:30 AM
Self Proclaimed Genius
Quoted: 0 Post(s)
Do you guys manhandle your gloveboxes or what? I've had mine off and on probably 20 times and it still works fine. All you have to do is spread out the nub when it starts to get loose on the shock.
Donahoe - Total Chaos - Deaver - Wheelers - Goodyear
SilverStreak05 is offline
#15 Old 02-05-2006, 03:20 AM
05 Speedwayblue X-runner
rpmspeedyBlue's Avatar
Quoted: 0 Post(s)
If I recall correctly there are two holes on the shock and you use the second one from the top. If you use the top hole the shock will pop off or bend the tab. otherwise it is pretty simple to put back together. There is no need to do any mod.
rpmspeedyBlue is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Tacoma Forum > 2nd Generation (2005+)
Quick Reply
Message:
Options
Register Now
In order to be able to post messages on the Toyota Nation Forum : Toyota Car and Truck Forums forums, you must first register.
Please enter your desired user name, your email address and other required details in the form below.
User Name:
If you do not want to register, fill this field only and the name will be used as user name for your post.
Password
Please enter a password for your user account. Note that passwords are case-sensitive.
Password:
Confirm Password:
Email Address
Please enter a valid email address for yourself.
Email Address:
Log-in
Human Verification
In order to verify that you are a human and not a spam bot, please enter the answer into the following box below based on the instructions contained in the graphic.
User Tag List
Linear Mode Linear Mode
You may post new threads
You may post replies
