clunk felt when done stopping! Please help - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Tacoma Forum > 2nd Generation (2005+)
2nd Generation (2005+) Discussion area for the 2nd generation of the Toyota Tacoma
Old 04-17-2006, 08:48 PM   #1 (permalink)
View scalder's Photo Gallery
After I am done stopping (full stop) I fell a dull clunk in my rear end......the way I describe it is its like a pop can rolling forward and hitting the cab. This is usualling a second delay after I stop. I can't imagine its the transmission but who knows please help....
scalder
2005 TRD access cab auto 22200KMS
scalder is offline   Reply With Quote
Old 04-17-2006, 09:38 PM   #2 (permalink)
Go Bills!
View ronk44's Photo Gallery
My dealer told me this is the Anti-lock brake system doing this.
2005 Double-cab, 2WD, V6 Prerunner, White, TRD Off-Road
K&N drop-in, Undercover tonneau, Aries black nerf tubes, Hidden tow-hitch, 8500K lights,
Redline hood struts, Valor chrome exhaust tip, Stubby antenna, Bug deflector, Metal pedals,
ronk44 is offline   Reply With Quote
Old 04-17-2006, 09:38 PM   #3 (permalink)
soundman34
View clfx34's Photo Gallery
I have the same thing. My truck has been doing it for a while and it also does it when pulling out from a stop also. The problem is the splined slip yoke. This part is sticking and that is the clunk you are feeling. Toyota is not putting enough grease in the slip yoke part of the drive shaft assembly, In fact they are pretty bone dry from the factory. Not sure why they do this. The underlying problem is the surface is not being made smooth enough during the machining process. I don't even think that Toyota makes this part, I believe it is made by GM, but I am not entirely sure about that. Toyota knows about this problem, but is not doing anything about right now. I have complained about it several times and they keep telling me it is characteristic of the vehicle. That is what they are scripted to say until there is a TSB for a specific problem which is BS. I have a friend that is a Toyota/Lexus mechanic and some of the SUV line of the Lexus is having the same problem. He is going to pull the drive shaft down and add some special grease. That will only be a temporary fix until Toyota comes up with a permanent fix. This problem really gets on my nerves in stop and go traffic. The problem is really bad in the summer when the temperatures are above 60 degrees. During those temps. the grease thins out and sticks more. Take your truck in and complain about it. They will probably give you the same lip service that I got. If you keep the pressure on you might be able to get them to grease the slip yoke part (under the black plastic boot), but the problem will come back eventually.
05 Silver DC 4x4 TRD off road with tow
clfx34 is offline   Reply With Quote
Old 04-17-2006, 09:44 PM   #4 (permalink)
The Manual Is Your Friend
View Maxshred's Photo Gallery
You may want to see a Dr. about this. I don't know if there is much Toyota can do for you.
~Dano
Power is nothing without control
Maxshred is offline   Reply With Quote
Old 04-17-2006, 10:32 PM   #5 (permalink)
Markass's Avatar
View Markass's Photo Gallery
~Dano
This is a very common problem.... been discussed here many times. Search for "clunk" or "lurch forward" in the '05 Taco forum for more.
Markass is offline   Reply With Quote
Old 04-17-2006, 11:41 PM   #6 (permalink)
View sdtaco's Photo Gallery
Yeah I have the same problem. Been noticing it more lately. I will be taking the Tacoma in for an oil change here soon and bring it up to Toyota just to push the issue a little more.
Harp
sdtaco is offline   Reply With Quote
Old 04-18-2006, 01:21 AM   #7 (permalink)
TacoSport05's Avatar
View TacoSport05's Photo Gallery
I think this sounds like something that has been described before on this board as "axle wrap." I too experience this condition as described. From what I've read, its deemed "normal" for our trucks.
With our trucks being somewhat complex pieces of equipment made up of something on the order of 20,000 parts, I'm not worried about this too much. I too was like many new owners who are a few weeks/ months new to TN and have gotten caught up in every little noise, flaw, and scratch. After having the truck for almost a year now, I've mellowed out and just enjoyed the truck. Don't get me wrong, I still wash the truck every few weeks and watch where I park, I'm just not as anal as I was a year ago. Shoot, if I was, I would never drive the truck- I'd just stand there looking at it! Just my two cents!
TacoSport05 is offline   Reply With Quote
Old 04-18-2006, 05:41 AM   #8 (permalink)
soundman34
The problem is not axel wrap. I have had this problem diagnosed twice now, once by the dealer and once by another Toyota/Lexus tech. I have had helper springs on since the 3000 mile mark and have had this problem with and without the super springs. When you come to a stop the spline yoke is sticking and sort of winding up the rear transmission so when you let off the brake you feel a clunk. That is the second part of the problem. The first being coming to a stop and starting from a stop (clunk). If it was not so annoying in stop and go traffic I could probably over look it until a fix comes out. I have had experience with this issue in two other vechiles(2000 ranger, Dad's F150) and both times it turned out to be the spline slip yoke. We just have to wait until Toyota gets going on the fix.
Old 04-18-2006, 05:58 AM   #9 (permalink)
Thank you everyone!!!!!
Just wanted to say a quick thanks to everyone.....I feel alot better now knowing that it is NORMAL....It is an amazing truck so every little noise I am obsessing about! HA! I will report it to the dealer so it will be on file
thanks again
keep on truckin
scalder
Old 04-18-2006, 09:22 AM   #10 (permalink)
Twinkle Twinkle
MrSmitty's Avatar
View MrSmitty's Photo Gallery
Thought I seen a grease fitting. Am I correct??..
I am going hit all the grease fittings this up coming weekend and fix that damn Catalytic converter rattle on cold start up.
MrSmitty is offline   Reply With Quote
Old 04-18-2006, 09:25 AM   #11 (permalink)
The Walking Carpet
View Waterwookiee's Photo Gallery
My current and last truck both had this problem. I finally figured it was just the gas sloshing in the tank. It only does it when it's between 90% and 30% full. To much, and it doesn't slosh, and too little, there isn't enought weight to slosh.
Sometimes the simplest answer is the correct one....
2005 base model, Silver Streak
Behold, Dori the "Wonder Taco"
Waterwookiee is offline   Reply With Quote
Old 04-18-2006, 12:49 PM   #12 (permalink)
soundman34
There is no grease fitting for the slip yoke. It is a sealed system. You have to drop the drive shaft and take the boot off and grease it that way and then re-install everything. That is what we are going to do to my truck here in the next week or so. If it lasts the summer I'll be happy.
Old 04-18-2006, 05:54 PM   #13 (permalink)
Jack
Jakaumo's Avatar
View Jakaumo's Photo Gallery
Take the Keg of beer out of the back of your truck. That should stop it from rolling and "clunking."
Jakaumo is offline   Reply With Quote
Old 04-18-2006, 11:33 PM   #14 (permalink)
Markass's Avatar
You seriously believe that? You're going to tell me that after I'm stopped for 7 seconds, "fuel slosh" is going to give me whiplash after overcoming the effing brakes?? (Okay, mild dramatization, but mine is CERTAINLY not "fuel slosh")
Old 04-19-2006, 05:51 AM   #15 (permalink)
View binmack's Photo Gallery
I have this like many other and yes it can be "fuel slosh"
I know from experience that fuel in and unbaffled tank can generate incredible force. The fuel does not just roll foward like a solid. Explaining the wave like motion that takes place would require a course in fluid dynamics but its energy is not released immediatly. it take some time. (not 7 seconds in my case more like 1 1/2 )
2010 Tacoma TRD Off-Road
binmack is offline   Reply With Quote
Clutch clunk smiljko Hardcore Tech and Competition 2 11-04-2004 05:02 AM
Front end suspension noise.. clunk, clunk hdsalinas Archived Corolla threads 9 05-31-2004 11:07 PM
G3 clunk in front end solved threedom Camry & Solara Lounge 2 04-07-2004 06:55 PM
