MPG Towing Results of a 06 DC LB 4x4 - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Tacoma Forum > 2nd Generation (2005+)
2nd Generation (2005+) Discussion area for the 2nd generation of the Toyota Tacoma
Old 04-25-2006, 09:11 PM   #1 (permalink)
06 DC 4x4 TRD Sport Tow
View Dakoma's Photo Gallery
Canada MPG Towing Results of a 06 DC LB 4x4
I haven't had a chance to tow anything and I'm curious as to the MPG performance while towing.
Anyone calculating their MPG while towing? If so, what were you towing and how much weight including passengers and any weight in the box? Did you have A/C while towing or windows rolled down?? Lot of hills to climb or wind???
Dakoma is offline   Reply With Quote
Old 04-26-2006, 06:24 AM   #2 (permalink)
Humble Servant
msibille's Avatar
View msibille's Photo Gallery
I have PreRunner DC, but fwiw, I get roughly the same mileage (made 1mph better) towing my boat on the interstate as I get in city driving. (~17mpg city or towing on interstate)
I'm towing a 1500 lb 17ft sailboat. Not a lot of weight but a lot of wind cross-section (fills the rear view mirror). Doesn't seem to make much difference how much wt is in the cab since I'm towing so much air drag.
msibille is offline   Reply With Quote
Old 04-26-2006, 08:03 AM   #3 (permalink)
demoncleaner's Avatar
View demoncleaner's Photo Gallery
Well I gotta short bed w/ a 6spd manual, but towing my 1000lb semi-enclosed snowmobile trailer drops my mileage a couple mpg. The drop most likely due to wind resistance because of fairing around the sled (for the salt spray) than the weight itself. Got 17 on avg, not bad considering the cold temps and running soft compound snow tires in winter.
demoncleaner is offline   Reply With Quote
Old 04-26-2006, 09:01 AM   #4 (permalink)
View tdh108's Photo Gallery
2005 DC SB off road windows up, fan on low, AC off, towing approx 4200lb. Boat, approx. 100lbs cargo in bed and cab, driver only, Got 11 mpg on somewhat hilly terrain.
tdh108 is offline   Reply With Quote
Old 04-26-2006, 10:37 AM   #5 (permalink)
View Major Woods's Photo Gallery
2005 v-6, 6-speed, 4x4, DC.
Towing a 2000lb boat/trailer combo on mostly flat CT highways. I'm getting 15mpg @ 65-70mph in the winter.
3 people in the truck and 100lbs of gear.
Major Woods is offline   Reply With Quote
Old 04-26-2006, 11:32 AM   #6 (permalink)
View DUKFVR's Photo Gallery
4X4 DC AT, towing about 2500 lbs no air ,some hills . Driving 65to 70 getting 14mpg. 2 people ,400 lbs of gear in truck
I get 20 running unloaded on the Hwy.
DUKFVR is offline   Reply With Quote
Old 04-26-2006, 09:49 PM   #7 (permalink)
Canada
I should also ask...what was your average MPG before towing and while towing. I understand if your running high rpm's then obviously you will experience lower mpg.
I have a 3000lb trailer with another 1000lbs of passengers and gear and I'm really anxious to see how my Tacoma's rpm's will perform. We have alot of hilly terrain but nothing too serious and I found that my mileage sometimes didn't really show much difference in my older truck.
Old 04-27-2006, 08:16 AM   #8 (permalink)
I know I usually get around 17.5-18.5 in the winter and 20.5 in the summer. When I was pulling I really worked the hills to my favor. Get as much speed going down hill (80 or so) and hold 2000 rpms on the way up. Speed would usually drop down to 70 sometimes 65 depending on the hill size. This allowed me to keep lower rpms and get a little better mileage. But I only did this for the second half of my trip. So, I think my mileage might be a little better if I do this consistently. Something I was quite suprised by was a friend of mine just got a brand new F-250 diesel and he is getting 9 mpg on flat ground running 70 pulling the same boat. Yes his truck pulled it better but the tacoma did just fine. However, if you plan on maintaining a set speed the entire time be prepared for 3000 rpms.
Old 04-27-2006, 01:27 PM   #9 (permalink)
View j4x4ar3's Photo Gallery
Towing 5300# travel trailer .. 26' long.. average 10mpg with DC shortbed 4x4. Have gone as low as 8 in 30mph head wind. 18-20mpg when not towing.
j4x4ar3 is offline   Reply With Quote
Old 04-27-2006, 02:12 PM   #10 (permalink)
french fried taters
stevenh563's Avatar
View stevenh563's Photo Gallery
How does your Tacoma do pulling that much weight? Ive never pulled over 1200lbs with mine, thats why Im asking.
06 toyota tacoma, 4x4, double cab, trd offroad, borla exhaust, green high perf. air filter, indigo ink pearl, 5spd auto,front windows tinted, access limited edition tonneau cover, aries stainless steel step bars,Mobil 1 EP oil filter M1-209 or Amsoil EA034, German Castrol 0w30
stevenh563 is offline   Reply With Quote
Old 04-27-2006, 03:03 PM   #11 (permalink)
View sdallas's Photo Gallery
Hi Guys, I am towing 5000 pounds. Probably average 10 MPG.
sdallas is offline   Reply With Quote
Old 04-27-2006, 07:51 PM   #12 (permalink)
Canada
When I do tow, I stay out of the fast lane and try to maintain rpm's at 2000 with 2500 going up hills. Sometimes I'd hit 3000 just before the top of the hill. While towing, I'd normally experience 2-3 MPG less. I'm not sure why some of the other responses have reported almost a cut in half in MPG performance. Of course, you were pulling more weight than 3000lb's.
Old 04-27-2006, 10:41 PM   #13 (permalink)
Towing 5000# isn't bad and is better than what I expected. Takeoff from start and getting on the HWY at 55 isn't really a problem (unless it's a short ramp). You definitely need a weight distribution hitch though to keep things level. I've done 5% grades at 50mph in 4th gear and have been able to pass fully loaded freight trucks in 3rd. It whinds up a bit but I've only hit 4000rpm once and rarely hit 3500rpm. Definitely need a good brake controller (Prodigy) but the truck handles the trailer pretty good. Gas mileage though with that big of a trailer sucks but it's no worse than the big boys get. Wind drag though.. hmm... V6 struggled a little with 35mph headwind but never had to drop it lower than 4th. 55mph though which is the speed limit for towing here anyway. Gas mileage in that situation hit the lowest I've had.. about 7-8mpg.
Old 06-20-2006, 12:37 PM   #14 (permalink)
View StreetToy's Photo Gallery
I just towed a 29' bumper hitch camper (4300 lbs) and got 7mph. I alos has a wife, two kids, bikes, mini bike and luggage in my DBL Cab 4x4 V6 Tacoma. The 30+ head wind did not help things either. I was pleasanly surprised with the performance and would estimate 10mpg+ in normal or low wind conditons.
I am going on a 100 mile trip this weekend with the same load. I will fill you in after the trip.
StreetToy is offline   Reply With Quote
Old 06-20-2006, 05:19 PM   #15 (permalink)
View NWTaco's Photo Gallery
4x4 AC Sport w/ tow package... towed a 4500 lb. uhaul trailer 2300 miles from Washington state to Texas. Went through mountains and through completely flat areas. Averaged about 12 MPG
I know it's not the same truck as yours, but figured the info. might help someone else!
NWTaco
06 Tacoma 4x4 Access Cab 5spd Auto
Silver Streak Mica
TRD Sport w/Tow Package
NWTaco is offline   Reply With Quote
Results! Premium vs. Regular fuel in 06 Avalon rbarbot 1st Generation (1995-1999) 5 03-30-2006 10:10 PM
Towing with my 06 DC 05tacoma 2nd Generation (2005+) 13 03-27-2006 04:50 PM
gas mileage 4x4 DC LB yellowlabs 2nd Generation (2005+) 18 03-21-2006 09:55 PM
06 DC TRD 4x4 rwhockeytown 2nd Generation (2005+) 2 02-26-2006 06:34 PM
06 sport DC LB Mirror etc.. n1wof 2nd Generation (2005+) 1 11-16-2005 12:25 AM
