Battery Relocation/Second Battery - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Tacoma Forum > 2nd Generation (2005+)
2nd Generation (2005+) Discussion area for the 2nd generation of the Toyota Tacoma
Old 05-05-2006, 02:45 AM   #1 (permalink)
cam2Xrunner's Avatar
Anyone have any good ideas for ways to mount the battery in the bed? Has anyone done a battery relocation yet, or added a second battery?
Old 05-05-2006, 03:10 AM   #2 (permalink)
View deff808's Photo Gallery
I would like to know as well
deff808 is offline   Reply With Quote
Old 05-05-2006, 06:07 AM   #3 (permalink)
View silversport's Photo Gallery
Is your bed covered? You could always go with a simple battery box. Not very innovative but think it would do the job...
http://www.jegs.com/webapp/wcs/store...tegoryId=23031
silversport is offline   Reply With Quote
Old 05-05-2006, 06:22 AM   #4 (permalink)
And My Dog Remington
Nicky9's Avatar
View Nicky9's Photo Gallery
You beat me to it! That is prob your best bet IMO.
http://store.summitracing.com/egnsea...DS=1&N=210+115
“All things are subject to interpretation whichever interpretation prevails at a given time is a function of power and not truth.”
2006 Tacoma DC Sport 4x4
Nicky9 is offline   Reply With Quote
Old 05-05-2006, 06:35 AM   #5 (permalink)
Theatre Nerd Person...yea
Sony's Avatar
View Sony's Photo Gallery
The Battery in this truck is pretty big, so make sure you get a battery box big enough to fit.
2006 Toyota Tacoma DCab Long Bed SR5 V6 5spd Auto 4x4
Tow Package, 6 CD Changer, Rear Limited Slip Differential, 16" Alloy Wheels
Silverstar H4 Headlamps and
Silverstar 9005 Foglamps, Bed Storage Utility Lock Mod, Redline Tuning Gas Hood Struts, Roll-N-Lock M-Series Retractable Tonneau Cover
Sony is offline   Reply With Quote
Old 05-05-2006, 08:44 AM   #6 (permalink)
View j4x4ar3's Photo Gallery
Go over to TS and look up TacomaOffRoadGrl. She's got dual optima's under her hood to keep her fridge running when she's away from the truck. She did a nice job.
j4x4ar3 is offline   Reply With Quote
Old 05-05-2006, 09:53 AM   #7 (permalink)
Nicky9's Avatar
Found this, its a dual battery setup over at Tundrasolutions.com she has a sweet setup:
TacomaOffRoadGrl
Old 05-05-2006, 09:58 AM   #8 (permalink)
PiercedTiger's Avatar
View PiercedTiger's Photo Gallery
nice! Thanks!
More details on the wiring would be nice... But it's a start and something to think about.
^sig by me!
Toytec 3" lift & AAL, 285/75r16 Kumho Road Venture
DTRL, Fog Light, locker, & diff breather mods, Bestop Supertop, Hi-Lift mount, hood struts, reinforced tailgate, BHLM, ABS kill switch, bed lights, rock lights
PiercedTiger is offline   Reply With Quote
Old 05-05-2006, 12:05 PM   #9 (permalink)
View hcarman's Photo Gallery
cptcrush added a second battery and isolator on passenger side under the hood. Check with him if he can provide any pointer.
2006 Silver Tacoma V6 Auto 4x4 DCab-Short Offroad
with roof-rack, trd skid plate, black running board
homelink mirror, truckcoversusa, pop-n-lock, heated signal mirror
raammat, ensolite, gilsson gps antenna
hcarman is offline   Reply With Quote
Old 05-05-2006, 12:38 PM   #10 (permalink)
Thanks for the tip!
I see the isolator, but I've never used one before so I'm sure on the wiring. Also wasn't sure what the circuit breaker was going to. Looks like isolator to yellow top pos terminal, but not sure looking at the pic.
^sig by me!
Old 05-05-2006, 03:22 PM   #11 (permalink)
Kool setup!
What about her Alternator?
More details on the wiring and isolator hook up.
Old 05-05-2006, 03:35 PM   #12 (permalink)
View '05kesslers's Photo Gallery
Some guy on TTORA has a full write up
My Ride
http://www.cardomain.com/ride/2199393
'05kesslers is offline   Reply With Quote
Old 05-06-2006, 07:56 AM   #13 (permalink)
Thanks.... found "some guy" this morning.
For the rest of you:
http://www.ttora.com/forum/showthrea...t=dual+battery
^sig by me!
Old 05-06-2006, 12:01 PM   #14 (permalink)
Awesome, thanks for the info!
I think I'm going to run a dual Odyssey PC1700MJT setup. I am getting my alternator rebuilt for 200+ amps
Old 05-06-2006, 12:32 PM   #15 (permalink)
N/A bites
Tercel GTS's Avatar
Thumbs up
I build alternators and setup charging systems for stereo competition so let me displace a few rumors and try to help out some.
1. Isolators are not required unless you intend to play the stereo while the vehicle is off and don't want to kill the cranking battery. Your amplifier won't appreciate the low voltage.
2. Running dual batteries is a good idea, make sure they are a matched set meaning same type and age. If one goes bad in 2 years replace both.
3. When running dual batteries they should be as close together as possible. Opposite sides of hood is allowable, one in bed other under hood will shorten the life of both.
4. Optima batteries do not have to be mounted upright nor do they require boxes, you can strap them under the bed securely and they'll be fine. Running a jump start access point would be a really good idea. Position the batteries so when they need testing you don't have to remove them first.
5. Dual batteries do not take the place of a high output alternator, they go hand in hand.
6. Grounding cables such as you see on ebay rarely do anything but add color.
7. Split the connections on the batteries where you can, like use the top post to connect to alternator, run the stereo lead to the side post. This lessens the corrosion and heat, therefore reducing the chances of bad connections.
8. On a dual setup make sure the alternator is charging one battery and the amps draw from the other. Both batteries can share one ground but don't forget to make sure the block and chassis are grounded.
alternator-+-+-fuse to amps
ground--------
9. Don't forget to fuse everything!
10. Take pics and show what you did.
雄のハヤブサ
Tercel GTS is offline   Reply With Quote
93 corolla battery warning light need help freemee22 Archived Corolla threads 11 05-16-2006 07:27 PM
More on this damn car battery! speedemn Camry & Solara Lounge 14 01-01-2006 09:21 PM
battery dead... Corollacrazy42 General Discussion 12 08-13-2005 11:24 AM
Battery ?'s 1995 camry V6 LE kenny1773 3rd & 4th Generation (1992–1996 & 1997–2001) 14 11-29-2004 03:29 PM
