Originally Posted by TcmaBoy
Toyota does option packages. To get certian things you have to buy the package it comes in. I believe that SR5 is the lowest trim level for the V6. You can go to toyota.com to price things out before going to the dealer. If it is a hunting and work truck you will be seeing mud. The TRD package with the e-locker may be something to consider.
Agreed.... 4wd and e-locker are a good thing to have. I don't hunt, but I do drive through fields and private trails you might take to a hunting spot. I've used the locker a couple times when the trail got muddy. You'll want those options if you ever venture off dry asphalt or dirt. lol Unless you always park on the side of the road and hike in or something similar.
Not to mention if you tow ATV's to hunt from having the tow package is good: extra oil cooler, bigger alternator, hitch and wiring.
I figured it was easier and cheaper to get those thing from the factory rather than try to do it myself later on.
^sig by me!
Toytec 3" lift & AAL, 285/75r16 Kumho Road Venture
DTRL, Fog Light, locker, & diff breather mods, Bestop Supertop, Hi-Lift mount, hood struts, reinforced tailgate, BHLM, ABS kill switch, bed lights, rock lights
