Outside edge of headlight rubbing on front fender - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Tacoma Forum > 2nd Generation (2005+)
2nd Generation (2005+) Discussion area for the 2nd generation of the Toyota Tacoma
Old 07-02-2006, 06:03 PM   #1 (permalink)
lamikela1's Avatar
View lamikela1's Photo Gallery
This weekend I was doing the black headlight mod. When I removed the headlights I noticed that the outside edge of the headlight was rubbing the front edge of each fender and had rubbed the paint off down to the metal. The right side was rubbing in two places while the left only in the area where the fender crease meets the front edge.
Here's a picture of the right...
and the left.
What I did to correct it was to bend in the egde where it was rubbing with a pair of pliers and coated it with some touch-up paint. That took care of the bare metal and should keep it from rusting later. It will also prevent the headlight from rubbing again.
The headlight mod went well thanks to all of you who added your comments in previous posts. Here's a shot of my mod. I did not have any problems with the paint rubbing off the reflector when reassembling the housing.
2005 DC LB, Indigo Pearl, TRD Sport, Custom Leather Interior
Fog light mod, Black Headlight mod, Pioneer AVIC-Z3, JL Audio, Autopage 1000 OLED
Map light mod, Zainoed, Undercover, Redline struts, Muth mirrors
lamikela1 is offline   Reply With Quote
Old 07-02-2006, 06:23 PM   #2 (permalink)
Pb
Surfing TN via iPhone
Pb's Avatar
iTrader Score: 15 reviews
View Pb's Photo Gallery
When I took out my lights I didn't notice any rubbing on the fender.
To keep it from rubbing again, try loosening the headlight bolts and pulling the headlight out a little bit. Or you can loosen a couple of the 10mm bolts that hold the fender to the truck. They are easy to get to. They are right on top of the fender when you pop the hood, in the jamb. Just loosen them up and then push in on the fender a little, then tighten the bolts back down. The mounting holes in the fender are oblong, for making adjustments like this.
Pb is offline   Reply With Quote
Drift Setting help for GT3 I hate Toyota Corp :( Off Topic 3 11-10-2003 10:36 PM
WTB 90celica GT Hatch Passenger front Fender asianchen Celica Forum 3 05-26-2003 01:28 PM
