TRD exhaust routing question - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Tacoma Forum > 2nd Generation (2005+)
2nd Generation (2005+) Discussion area for the 2nd generation of the Toyota Tacoma
Old 07-14-2006, 06:15 AM   #1 (permalink)
TacomaFourplay's Avatar
View TacomaFourplay's Photo Gallery
Hello all, I am currently in Iraq but as soon as I get back I will be picking up my truck (DC LB 4X4 SDWY BL Sport) and I am planning on doing a few things right away.
Question is... Is the TRD ehaust routed different than the regular ehaust. I am pretty set on getting the trd exhaut anyways. I have read here and there that the regular factory exhaust hangs down somewhere around the t-case and is pretty low at one point. I am just wondering if getting the trd exhaust would eliminate that. Thanks for your help guys.
Tony
TacomaFourplay is offline   Reply With Quote
Old 07-14-2006, 08:07 AM   #2 (permalink)
View yrffej's Photo Gallery
no, the trd cat back changes nothing, all the routing you're mentioning happens just foward of the cat back mounting point.
'05 prerunner access trd sprt pkg1 w/tow & trd catback
yrffej is offline   Reply With Quote
Old 07-14-2006, 09:08 AM   #3 (permalink)
demoncleaner's Avatar
View demoncleaner's Photo Gallery
Yep, the TRD Exhaust won't change the fact that the left Y-pipe hanges below the cross member behind the transfer case. The TRD muffler can is a bit smaller, reducing its chances of been hit. But that would be rare if it did happen.
demoncleaner is offline   Reply With Quote
Old 07-14-2006, 09:47 AM   #4 (permalink)
Thanks for the replies guys. I have not personally seen the extent of how far teh pipe actually hangs down.. Is it to an extent that it should be re-routed? Is there a common solution? I recall one person on this forum saying that their pipe had already dented a little.
Old 03-23-2007, 06:10 PM   #5 (permalink)
let's kick this pig.
nuckinfuts's Avatar
View nuckinfuts's Photo Gallery
It hangs down too far, I've flattened mine along the whole length of that crossmember. Has anyone found a decent solution to this problem?
nuckinfuts is offline   Reply With Quote
TRD Exhaust Owners Kamper 2nd Generation (2005+) 64 04-28-2006 04:23 PM
TRD Exhaust hclee25 Camry & Solara Lounge 3 10-28-2005 02:27 PM
TRD exhaust badazzlegnd 2nd Generation (2005+) 31 10-23-2005 09:09 PM
if anyone would know,you guys would ;exhaust question , helppppp bigpeterock29 Camry & Solara Lounge 55 06-16-2005 01:09 PM
TRD exhaust ?? jofrad Archived Corolla threads 1 06-14-2004 01:35 PM
