4WD Fuse??? - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Tacoma Forum > 2nd Generation (2005+)
2nd Generation (2005+) Discussion area for the 2nd generation of the Toyota Tacoma
Old 07-21-2006, 07:17 PM   #1 (permalink)
View jkempster's Photo Gallery
4WD Fuse???
Ok, I was doing some wiring today. I bought one of the add a fuse blade thing to add a fuse for my garmin GPS to be hard wired. I was going to just tap off the cig. lighter but I can't get to those wire very easy. So I bought the add a fuse thing. I found the power outlet fuse and pushed this thing in there and I thought all was well, but then I noticed that my outlets don't go out when I switch of the ignition anymore.
WTF. I was very confused at this point. So the power to 12v outlets is always on at the fuse panel but switched by the time it gets to the actual outlets. That is all I could figure out.
So, sent I had to come up with plan B and my truck was in a million pieces I started looking at the other fuses in that panel. That's when I came across a 20 amp 4WD fuse. I have a pre-runner so more confusion. Well I used the add a fuse on this thing and it worked fine. When I shut off the truck the connection lost power.
So what exactly is the 20 Amp fuse. Is it just there because or have a done something wrong by using this one??
Thanks for your help,
Jeff
Jeffrey P. Kempster
http://jeffkempster.smugmug.com/gallery/797635
jkempster is offline   Reply With Quote
Old 07-22-2006, 03:34 PM   #2 (permalink)
Anyone have a comment.
Thanks again
Jeffrey P. Kempster
Old 07-24-2006, 09:11 AM   #3 (permalink)
RTFM's Avatar
Gameroom cash: $334162
View RTFM's Photo Gallery
I've got the wiring diagrams at work, will check there later today. Sortof a bump.
06 DC LB, 4x4, Speedway , TRD Sport w/ Tow, JBL 6CD w/ Grom to IPod, Roof Rack, Weathertech bug deflector & floormats, Access LE tonneau, Hood Struts, Scangauge, Clifford 10.5x alarm, Homelink Mirror, Ultra Grinder Wheels, Toyo Open Country AT tires
RTFM is offline   Reply With Quote
Old 07-24-2006, 01:38 PM   #4 (permalink)
RTFM's Avatar
4WD Fuse 20A is switched on the IG1 circuit (truck on), same as a few others. Only goes directly to the 4wd ECU, so probably no problem using it.
And the cig lighter sockets are switched by the ACC relay, when the key is in the ACC position. This is why people did the always on mod, to bypass the ACC relay to the cig outlets.
Old 07-24-2006, 03:05 PM   #5 (permalink)
Thanks for the help. I don't intend on plugging in too much anyway, but its nice to know that I am not pulling from something else.
Jeffrey P. Kempster
HOW TO: 2005-06 Fog Light Modification SWTRDSPORT 2nd Generation (2005+) 110 10-24-2011 07:40 AM
Scion FUSE: An Evolution [Video On Demand Documentary]! ScionVIP Scion Forum 0 04-12-2006 02:34 PM
HELP - 4WD Engaged??? davet100 T-100 1 12-06-2005 09:27 AM
05 tacoma fuse problem DudeGuy 2nd Generation (2005+) 1 08-23-2005 11:54 PM
Power Windows/Locks Fuse Location mconboy Camry & Solara Lounge 8 07-14-2004 07:43 PM
