Anybody used tow-n-see mirrors?? - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Tacoma Forum > 2nd Generation (2005+)
2nd Generation (2005+) Discussion area for the 2nd generation of the Toyota Tacoma
Old 08-07-2006, 12:43 AM   #1 (permalink)
View Austone's Photo Gallery
Canada Anybody used tow-n-see mirrors??
Found a towing mirror called Tow-n-see. just wondering if anybody has any experience with them. Whats your thoughts on this brand.
Thanks
Austone
Austone is offline   Reply With Quote
Old 08-07-2006, 07:44 AM   #2 (permalink)
Synchman's Avatar
View Synchman's Photo Gallery
Yes, I use them. They work surprisingly well. They don't have a vibration problem. You can use your power mirror adjustor to adjust them, as they are stuck to the surface of the stock mirror.
They have a suction cup, with a diaphram. You turn a screw that moves the diaphram, to evacuate air from the cup. There is also an elastic loop that goes around your mirror in case the Tow-N-see gets knocked off somehow.
I strongly recommend the convex mirror for the passenger side, possibly for both sides.
I was not sure if they would extend far enough to see behind my trailer, so I wrote the manufacturer, and obtained the following:
"Hello Scott:
The mirrors can extend approx. 8 1/4 inch . Height of the mirror is 5 1/4 inch, width is 5 5/8 inch. The suction cup is about 2.5 inch in diameter. Hope this answers your question. Tens of thousands are being used in Europe, we just were awarded 2nd place for Accessory of the year 2006 by a prominant Dutch RV magazine.
Hope this answers your questions. You can find more info on our web site:www.tow-n-see.com "
In response to a PM:
My trailer is generally 94" wide, but if you count the bubbled-out taillights and the supports for the awning it is 97" wide.
Generally the obstructed width is 96".
The Tow-N-See mirrors extend the inboard most edge 4" beyond the outer edge of the Taco mirror, and the outboard most edge 8" from the outer edge of the Taco mirror. (The Tow-N-See mirror surface is 4" wide).
So if your 84" outside dimension is correct, the outer edges of the Tow-N-See mirrors mounted would be 100" apart, the inner edges would be 92" apart.
Here is a pic of my Taco with the mirrors attached:
Scott (Synchman)
2005 Taco DblCab LB V6 4X4 AT
2007 Rav4 V6 AWD AT Ltd
http://www.cardomain.com/ride/2287946/1
Synchman is offline   Reply With Quote
Old 08-07-2006, 01:28 PM   #3 (permalink)
Synchman's Avatar
See also:
http://www.tundrasolutions.com/forum...ilable-online/
Scott (Synchman)
Old 09-17-2007, 07:56 AM   #4 (permalink)
this_is_nascar's Avatar
View this_is_nascar's Photo Gallery
I'm interested in these mirror extenders. Have you had any long-term issues with the motor of the OEM mirrors?
Current Ride: 2007 Toyota Tacoma TRD Off-Road Stock)
Former Ride: 2001 Ford Ranger XLT Off-Road (Stock)
"... it's not what you take when you leave this world behind you, it's what you leave behind you when you go."
this_is_nascar is offline   Reply With Quote
tow mirrors? fireman9170 2nd Generation (2005+) 9 05-22-2006 10:49 AM
Would you buy Tow Package without LSD for $25K? guymenton 2nd Generation (2005+) 7 03-29-2006 09:39 PM
Should I paint my mirrors to match? dna59 General Discussion 2 02-16-2006 01:57 PM
Tundra towing mirrors rvboy 1st Generation (2000–2006) 6 10-27-2005 11:34 AM
