2006 Tacoma Immobilizer in key - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Tacoma Forum > 2nd Generation (2005+)
2nd Generation (2005+) Discussion area for the 2nd generation of the Toyota Tacoma
Old 08-07-2006, 06:18 PM   #1 (permalink)
Mercury0_0's Avatar
View Mercury0_0's Photo Gallery
2006 Tacoma Immobilizer in key (with pics)
Is the immobilizer in the key one that needs to touch the key itself or is it one that transmits wirelessly? I want to get one of the switchblade key fobs and it looks like I'll have to transfer the immobilizer over to the new fob. I'd like to know if I'll have to find some way for it to touch the key or just find room in the fob. Has anyone done this yet? Thanks,
John
Mercury0_0 is offline   Reply With Quote
Old 08-07-2006, 08:32 PM   #2 (permalink)
View slow231's Photo Gallery
it's seperate, it doesn't have to touch anything just be near the lock cylinder when it's starting (it doesn't have to be near there for the truck to stay running). just cut away the protective rubber on one of your old keys, and it will expose a hard plastic casing, the chip is just held in the plastic casing.
slow231 is offline   Reply With Quote
Old 08-08-2006, 12:04 AM   #3 (permalink)
Mercury0_0's Avatar
Fanbloodytastic. Thanks Slow!
John
Old 08-08-2006, 12:13 AM   #4 (permalink)
View TAZZX2's Photo Gallery
you could always get a bypass kit dis *or other co* thats made to bypass the imobilizer for remote starts and wire it on at all times so you can cut any key you want....
This article brough up a nice point that there may be some kinda back door bypass to the coded keys http://www.wired.com/wired/archive/14.08/carkey_pr.html Not really what your looking for but interesting none the less
TAZZX2 is offline   Reply With Quote
Old 08-08-2006, 01:24 AM   #5 (permalink)
Taco Newbzr
View jdmbb's Photo Gallery
can u tell us what type of switchblade key fob ur looking at and where to get it cause i think it would be a cool thing to have. thanks
Scion xB --> Turbo Civic Hatch --> 06 X-Runner BSP
jdmbb is offline   Reply With Quote
Old 08-08-2006, 05:41 PM   #6 (permalink)
Mercury0_0's Avatar
Here is a link to the one I'm going to get for my '06 Tacoma ( http://www.toyotanation.com/forum/t112356.html ) And this is one I'm going to try and make work with my CBR F4i ( http://www.toyotanation.com/forum/t147654.html ). I can't wait to get 'em and get 'em working. I'll do photos and a write up when I'm done.
John
Old 08-08-2006, 11:49 PM   #7 (permalink)
Taco Newbzr
awesome let me know how it goes. are you gonna swap the controls from the stock keyless entry also into the new key?
Old 08-09-2006, 12:07 AM   #8 (permalink)
Mercury0_0's Avatar
I'm going to get the whole alarm kit so the controls in the switchblade key will use it's own electronics to make things work.
Old 08-14-2006, 11:04 PM   #9 (permalink)
Mercury0_0's Avatar
Photos of Immobilizer
I just got my truck today and I can finally cut a key open and see what the Immobilizer looks like. Here is the key being cut open.
Here the rubber is removed. You can see the Immobilizer peeking out on the right.
Here the plastic is being broken away and the Immobilizer is out.
Here it is completely apart.
Now I have to wait for the Switchblade key to arrive and then I will cut the key and install it and the Immobilizer into the new Switchblade FOB. I can't wait to see how it works. I'll post
pics as soon as I get it working.
John
Oh, I forgot to mention, I tried using the key with the Immobilizer about 6 inches away from the key and
it did NOT work. I tried again with the Immobilizer half a cm away from the key and it DID work. So it looks
like slow231 was right and the Immobilizer does not have to be touching the key to work. Yeah!
Old 08-14-2006, 11:25 PM   #10 (permalink)
Taco Newbzr
when you get the switchblade key se if you can take it appart and if the stock key will fit in place of the one it comes with if you can. thanks
Old 08-14-2006, 11:32 PM   #11 (permalink)
Mercury0_0's Avatar
Absolutely. I read somewhere that there are two very small screws that hold the key in place. I have not been able to confirm this yet though. As soon as I get it I'll let ya know.
Old 08-24-2006, 08:12 PM   #12 (permalink)
Mercury0_0's Avatar
Ok, I got the Switchblade key with the TRD logo on it. It's great! Works like a charm. I took the blank out of the fob with one small screw and took it to get cut. I then took the switchblade fob apart and glued the Immobilizer inside towards the key end. I put it all together and tried it out. Snickt... out comes the key. Into the ignition, turn and the engine starts. Whaahoooo. The Immobilizer is definately close enough for it to be recognized by the truck. Awesome. I've got the Autodoodad key and alarm comming soon. I'm going to switch the Immobilizer into it and hook up the alarm. The TRD logo switchblade key I'm going to use a dremel to cut and shape my CBR 600 F4i key and install it. Here are some photos of the TRD fob apart and a close up of the part of the key that goes into the switchblade.
I've got an Autodoodad switchblade key fob on the way so I used this TRD switchblade key fob for my CBRF4i. I had to use a dremel and cut and shape the key to get it to fit. Amazingly it worked. Here are the photos.
2006 Tacoma Dealer Incentives? GrantGrant 2nd Generation (2005+) 20 05-05-2006 11:24 PM
My 2nd Post, Just installed new Tonneau cover on 2006 Tacoma currentsupply 2nd Generation (2005+) 18 03-23-2006 12:36 PM
2004 Tacoma ride comparing to 2006 Tacoma Timmons 1st Generation (1995.5–2004) 1 03-20-2006 03:57 PM
First Drive...2006 Tacoma Count 2nd Generation (2005+) 6 11-07-2005 02:53 PM
Immobilizer Security key system cracked virtualkuz General Discussion 4 01-29-2005 08:09 AM
